Thread: FYI: Electrical System Issue
  1. FYI: Electrical System Issue
    Jan 2009
    Audi A3 8L chassis, Golf 4 & Seat models based on VWAG A4 chassis (Golf 4) require inspection of (1) the two earth / ground points located under the engine compartment mounted battery and (2) the positive (+) primary battery circuit located at battery and primary fuse panel mounted directly on top of battery (located in engine compartment)
    the issue is corrosion of copper conductors / leading to high resistance / reduction of conductor cross section area / rapid heating / potential fire hazard
    (internal) service bulletin directs technician to inspect primary positive circuit, remove battery and inspect earth/ground threaded stud points beneath battery molded resin support tray
    clean all earth/ground brass cable/wire terminations using fine emory or production paper (280-400 grit) and if NO broken conductors or obvious green corrosion within conductors, to spray with suitable contact cleaner/preservative spray and re-install. do not over-tighten relevent stud nuts or resin tray bolts
    of particular important is condition of (1) earth/ground cable between battery post - center heavy lug - starter solenoid post
    the center lug can become badly corroded by battery acid fumes / road salt / dampness resulting in the fine multiwire core breaking down with loss of current capacity - seriously overheating...
    also of importance is primary fuse distribution panel above battery - must be free of corrosion damage - loosen fuse nuts and apply contact spray and re-tighten with care - do not over-tighten!!! - DO NOT sand tinned surfaces!
    always disconnect battery before inspecting/re-tightening primary fuses
    yes you must scan for fault codes and clear afterwards
    I am only posting because with care, diy is possible, but carelessness can easily result in expensive damage to your car...
  2. Re: FYI: Electrical System Issue
    Jan 2009
    note: if there is any question as to service suitability of earth/ground cable (battery post cable) or primary fuse distribution panel - one or both components must be replaced
    DO NOT attempt to solder heavy center earth/ground lug on heavy cable if corroded or broken conductors present
  3. Re: FYI: Electrical System Issue
    Jan 2009
    I do not want to do multiple posts
    would moderator please add to relevent audi tt and seat and golf 4 threads
    thanks
  1. 05 2.0tdi Idle issue & '97 1.8 engine issue
    By dbbear in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 18-08-2009, 02:11 PM
  2. Question EGR System for TDI's - Keeping intake system clean
    By Audichap in forum Leon
    Last Post: 12-10-2008, 12:19 AM
  3. Question Odd Electrical issue - 2.0E ABK 1992
    By muz666 in forum 80 - 90
    Last Post: 29-09-2008, 10:10 PM
  4. Please Help How do I reset the electrical system on my '03 Passat after changing the battery?
    By rsmith710 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 08-07-2008, 06:35 PM
  5. Electrical issues. Security system.
    By acoccoluto in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 04-12-2007, 09:48 AM
