Thread: Leaking Water Pump
Results 1 to 10 of 12
  1. Leaking Water Pump
    Jan 2009
    Hello
    Have a 2000 sharan tdi and been loosing water just below the cambelt, near the water pump. Is it normal for a pump to leak?, car drives ok and does not over heat, could it be just a leak in the pipes. I loose about 1/2 a litre a day just from dripping. Ive been told that i need a new pump fitted but it is rather costly so any advice is hugely appriciated.
    Thanks.
  2. Re: Leaking Water Pump
    May 2008
    There should be NO leaks from the pump area. You'll need a new pump. It will only get worse and could fail altogether leading to possible head gasket or engine damage.
  3. Re: Leaking Water Pump
    Jan 2009
    Thanks Issac, will have it sorted tomorrow.
  4. Re: Leaking Water Pump
    Jul 2006
    scunthorpe
    the water pump is split in two, you can change just the impeller side which is a lot less hassle then changing the whole pump, there is a core plug in the pump housing this tends to rust from the outside in, while the cam cover is off it might be a good idea to change the cambelt as well, kill 2 birds with 1 stone as they say
  5. Re: Leaking Water Pump
    1836 Post(s)
    Quote Originally Posted by ufuk View Post
    Thanks.
    Costly! They are only £36 genuine, less pattern. How much were you told a new pump is?
  6. Re: Leaking Water Pump
    Jan 2009
    Andy E, Thanks for the reply, had a cambelt changed about 10k ago but i've been told to replace again as after it's been re-stretched it may not be as strong. what do you think?
    Crasher, Thanks for the reply, to supply and fit a new(recon) pump £250 but im not sure if that included a suggested cambelt change.
    I dont really want to keep spending that sort of money on this car, it never seems to stop.
    So far, air con compressor now it leaks and i gave up on that , screen wiper unit, central locking unit, very expensive clutch change, air flow meter, endless tyres, and only done 100k dread to think what it may cost next time. Head gasket ?
  7. Re: Leaking Water Pump
    1836 Post(s)
    Which engine code is in your Shalarxy, 1Z, AHU, AFN, AVG or AHU?
  8. Re: Leaking Water Pump
    Jan 2009
    Hi, The engine code is AVG.
  9. Re: Leaking Water Pump
    1836 Post(s)
    The coolant pump on an AVG is not cam belt driven, it is external. The official VW time is 220 time units so around 2 and a half hours.
  10. Re: Leaking Water Pump
    Jan 2009
    sounds like i am being scammed big time here. I will visit another garage this week and see what they say.
    Is 220 inclusive of parts?
  1. t4 starting probs and leaking pump Sorted
    By lostboy in forum The Commercial Range
    Last Post: 10-01-2009, 09:07 PM
  2. 80 TDi 1Z leaking diesel pump
    By adyjoad in forum 80 - 90
    Last Post: 13-04-2008, 07:11 PM
  3. Leaking water
    By dtwoi in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 23-01-2008, 10:40 AM
  4. Water leaking into footwells
    By agrundy in forum Golf MK4 - 1999 - 2004
    Last Post: 08-12-2007, 01:43 PM
  5. Vacuum Pump Leaking Oil. What does this mean??
    By lennymfo in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 12-10-2007, 05:19 PM
