Thread: Polo ABS warning light
  1. Polo ABS warning light
    Feb 2007
    I have a 2000 model 1.0e and the abs warning light comes on when I reach 20 mph. It goes out when the ignition is switched off and then on again.I have checked with a code reader and it says abs power unit fault. I have proped the front end and 'driven' up to and past 20 mph and NO LIGHT. If it was the main unit fault wouldn't the light still come on?
    I suspect that it is a wheel sensor, how can I check??
    Dec 2006
    ABS sensor at fault there..
    To find out which one you will have to use vag-com and read the fault codes..
    RicKT
  1. 2002 VW Polo Exhaust Emissions Warning Light
    By Lilly in forum Polo - Derby - Lupo - Fox
    Last Post: 20-12-2009, 01:11 AM
  2. polo gti abs warning light
    By gtifan in forum Polo - Derby - Lupo - Fox
    Last Post: 18-06-2009, 04:47 PM
  3. Water temp warning light flashing from cold - 98 Polo 1.4 auto
    By Scudetto in forum Polo - Derby - Lupo - Fox
    Last Post: 05-04-2009, 10:23 PM
  4. Polo emission warning light
    By davidpboden in forum Polo - Derby - Lupo - Fox
    Last Post: 26-01-2008, 10:13 PM
