Thread: where is the throttle body
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 31
  1. where is the throttle body
    I am having idle/stalling issues with my 1.8t and figure I would try and clean out the throttle body.
    Only trouble is I don't know how to find it or what it looks like!!!
    Please advise as cant afford to go to a garage, my fault codes are constantly the same, I have already cleaned out the MAF sensor a few weeks ago.
    Sorry if its an obvious question, I haven't bothered under the bonnet since last century!!
  2. Re: where is the throttle body
    South Moreton, Oxfordshire
    I'm pretty sure it's position is the same as my 2.0lt which is at the rear of the inlet manifold practically up against the bulkhead, it's quite tight to get at.
  3. Re: where is the throttle body
    Cheers mate, I will have a look after, sounding too big a job for me already.
  4. Re: where is the throttle body
    The inlet ducting came off mine and it was a right pig to get back on, it's a tight space and the throttle body is hidden by vacuum hoses etc. May not be so bad on the 1.8t I can't tell as my Haynes book shows the 2.0ltr ALT engine as an example.
  5. Re: where is the throttle body
    thanks again, its pouring it down here so I will not be investigating till later, just hope i can get to school after without stalling in the middle of a junction.
    Might sell the car and get an old banger, at least you can find stuff in the engine bay!!!
  6. Re: where is the throttle body
    What makes you think it's the throttle body, may just need booking in for a service.
  7. Re: where is the throttle body
    not had it long and been nothing but fault codes, took it back to ******* who sent it to a garage for a few days and fitted a new d.v. been running ok with the fault codes(cleared peiodically) but now having the idle and stalling issues.( serviced by dealers) Reading up on various forums etc has led me to think its got a bit coked up. Too tight for a full service and check up and not got enough knowledge anymore to do my own.
    My head is sore with all the research, might use the bus.....
  8. Re: where is the throttle body
    Dec 2007
    Quote Originally Posted by bigdavehep View Post
    could be the maf i know you said you cleaned it but could still be maf
  9. Re: where is the throttle body
    you think??
    lost my sheet with all the codes I have had but I remember various misfires,16891 idle control too high - sporadic, 17544 system too lean, and 17705 pressure drop between turbo and throttle valve, and the latest is 18034 powertrain databus missing message p1626.
    Ran a bit better this morning, was it luck or because its not -6 degrees outside?
    Would it be advisable to put a new MAF sensor in at about £50 ?
  10. Re: where is the throttle body
    To update, I removed the MAF sensor plug and it still tick over like a 3 leged dog, does that automatically mean its not the MAF?
    Thanks in advance to the more knowledgable members.
  1. New throttle body - please help
    By tinke in forum Polo - Derby - Lupo - Fox
    Last Post: 08-08-2013, 04:05 PM
  2. Question 1.4 16v throttle body
    By ricky.dub in forum Golf MK4 - 1999 - 2004
    Last Post: 27-11-2008, 07:20 PM
  3. throttle body on 1.8 gti
    By peterdenson in forum Chat - Anything with wheels
    Last Post: 22-05-2008, 08:16 PM
  4. throttle body
    By slim1986 in forum Golf MK4 - 1999 - 2004
    Last Post: 19-03-2008, 08:24 PM
  5. Throttle Body
    By Fibreron in forum Passat - Archive Topics
    Last Post: 26-12-2007, 10:51 PM
