Thread: electric window wont fully close
  1. electric window wont fully close
    Jan 2009
    the drivers window on my 96 saloon starts to close, then, as if it is hitting an obstruction, it stops and opens again as if it is hitting an obstrucrion. If I tug and jiggle it whilst it closes, I can (eventually) get it to close to about 1" from fully closed....having scanned the forum this does not appear to be a regular problem, but the passanger window has never worked, although I can detect a tiny clicking noise if I try to open it!!
    Help please someone
    thanx, martin
  2. Re: electric window wont fully close
    Crosby, Liverpool
    Sounds like sticky runners. Try a bit of lube in the channels the glass runs in,WD40 etc. Should loosen it up nicely
    Audi A4 B5 1.6 -1998 <~~~ GONE
    Audi A4 B7 2.0 - 2005<~~~ GONE
    Audi A4 B5 1.8 T 1996 <~~~Here for now
  3. Re: electric window wont fully close
    Jan 2009
    Hi! I whaked in a gd rip of wd then opened it fully for the first time.... and it got stuck, then a bit of a crunchiung thud .. I pressed close..up it went, stopping twice before closing all the way - thank goodness. I ha a tentative stab at opening again, but nothing - i'll try again when it's warmer!!
    thanks for your help
    oh the drivers door inside opener failed about a week ago. I opened the window and used the outside handle and after that it was fine again....could this be connected...so to speak...do you think?
  4. Re: electric window wont fully close
    Aug 2007
    East Anglia
    my 2003 a4 1.9tdi drivers window had same thing.
    garage said it was the cable in the mechanism had frayed, so it was catching when trying to open/close the window.
    apparently new mechanism unit part £72+couple of hours labour.
    (Still need to get it done...long pockets+short arms!).
  1. T4 wont start unless I close the relay?
    By vma99r in forum The Commercial Range
    Last Post: 14-02-2009, 06:51 PM
  2. a4 tailgate wont close
    By blackwall in forum Chat - Anything with wheels
    Last Post: 09-12-2008, 07:02 PM
  3. Bonnet wont close
    By waynetdi130 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 12-10-2008, 10:31 PM
  4. Is there an allen key slot to close an electric sunroof on a mk3 golf?
    By Ricardolphin in forum Chat - Anything with wheels
    Last Post: 18-09-2008, 12:50 PM
  5. Please Help electric window wont close properly
    By sumomus_01 in forum Golf MK4 - 1999 - 2004
    Last Post: 28-07-2008, 09:03 AM
