Thread: VW POLO 96 turns over won't start
Results 1 to 10 of 10
  1. VW POLO 96 turns over won't start
    Jan 2009
    Hello,
    I have a VW Polo 1.4 1996 that will not start, and no idea what it is. we thought it could be due to battery but change battery and spark plugs and cleaned/tightened connections. tried jumping it as well. when u turn the ignition it turns over and over and just don't start.
    I realised that when i was trying to start the engine i couldn't smell any petrol even though i was pumping the throttle, even when i smelt right up close. i looked closer at the pipes that the petrol flows through and no petrol in them. It puzzles me though as i was driving the car the day before and now nothing.
    We now think it may be the relay for fuel pump or a problem with the fuel pump. If it is the relay can somehelp with what number is it in my car as do not have diagrams. anyone else know what it might be ??
    Have now replaced the fuel tank relay still no petrol running through to engine, i listened to the fuel pump up close and i can hear the buzzing noise? anyone know what might be wrong?
  2. Re: VW POLO 96 turns over won't start
    Jan 2009
    anyone have an idea
  3. Re: VW POLO 96 turns over won't start
    Aug 2007
    Hook Hampshire
    21 Post(s)
    Despite the engine not starting, does it fire?
    Before we check other parts, please do the following. Disconnect the fuel pipe that enters the fuel rail. Turn the ignition on to see if petrol shoots out the pipe. This is the only way to check that the fuel is not being pumped. If fuel is flowing then the injectors are not opening. Let me know the result and we can take it to the next stage.
    Also, spray some carb cleaner into the throttle valve. Turn the engine over. If it fires, we know that no fuel is enterring the engine. If it does not fire then we know that there is a spark issue.
    Audi A7 3.0TDi 2011 160k miles, engine code CLAB 204bhp 2WD
  4. Re: VW POLO 96 turns over won't start
    Jan 2009
    Reading
    if you have fuel and spark, could well be a crank sensor or similar engine management issue. It needs a diagnostic computer to check trouble codes, dealer is very expensive so i would look for an independent garage with a snap on or other universal make reader. Maybe they will bring reader to your car if it wont start.
  5. Re: VW POLO 96 turns over won't start
    Jan 2009
    Quote Originally Posted by shabazmo View Post
    ok ive tried that but there is no petrol flowing at all through the engine and at the fuel pump, someone told me that it could be due to the thatcham alarm on it and i need to enter the code for it again could that cause petrol to not flow?
  6. Re: VW POLO 96 turns over won't start
    Aug 2007
    Hook Hampshire
    21 Post(s)
    Not too sure what you mean, does it fire when you put carb cleaner through the throttle valve and not fire when when no carb cleaner is put in.
    When you say no petrol is flowing through the engine. I need to know how you tested this. My test in my previous post is the simple way.
    I cannot take this post any further without a more accurate reply from you.
    I can provide you with a dozen reasons why the car wont start but it will not fix your problem unless you replace all parts. A systematic diagnostic procedure is what is required to establish the correct fault
    Regards.
  7. Re: VW POLO 96 turns over won't start
    Aug 2015
    south africa
    I have a 96 polo it gets fuel and spark but it just won't start had it at an autolec and replaced the ecu 7k later it still doesn't start. can u please help me
  8. Re: VW POLO 96 turns over won't start
    Aug 2007
    Hook Hampshire
    21 Post(s)
    Can you tell me if the engine fires when you try and start it. If not put carb cleaner or easystart in the throttle Chamber and tell me if the engine starts or even fires. If neither, you need to do a compression test on all 4 cylinders. Let me know how you get on.
    there will be a lot more testing before we know what to replace.
  9. Re: VW POLO 96 turns over won't start
    Jul 2007
    glasgow
    35 Post(s)
    Also you could replace the fuel filter ?
    Have you put in a gallon of fuel incase the tank is empty due to faulty fuel guage sender unit in tank ?
    failing that you could try hitting the fuel pump incase its seized, however the fuel pump might be faulty
  10. Re: VW POLO 96 turns over won't start
    Jul 2017
    Hello.
    Remove all your spark ignition, clean them all
    Removed your distributor casing, heat it up a little bit with a lighter and refix it.
    Start your engine. Guarantee it will start after that you need to check if your TPS sensor is working, if not, unburn petrol will remain in your cylinder head which will cause your spark ignition to become dark.
  1. Turns over but won't start
    By Steven Alexande in forum Passat - B5 Forum - 1997 -2005
    Last Post: 26-08-2008, 12:48 PM
  2. Non starter, engine turns alright but wont start A4 1998 1.6 petrol
    By kobby in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 20-03-2008, 10:16 PM
  3. Car turns over but wont start...
    By kjopen in forum Golf MK3 - 1993 - 1999
    Last Post: 08-03-2008, 04:06 AM
  4. starter turns but engine won't start
    By ser17 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 20-02-2008, 06:35 PM
  5. Another Polo won't start
    By polo14 in forum Polo - Derby - Lupo - Fox
    Last Post: 01-02-2007, 10:23 PM
