Thread: Low Washer Fluid warning on permanently. Where is sensor located?
  1. Unhappy Low Washer Fluid warning on permanently. Where is sensor located?
    Mar 2008
    Hi there,
    After a trip to the French Alps this Xmas and temps below -9 deg C, the low washer fluid warning symbol is now permanently displayed on my 08 plate A3 sportwagon with electronic dashboard display. (Not fitted with headlamp wash)
    It was fine before the trip.
    I suspect the water in the reservoir froze at some point.
    Could this have damaged the sensor?
    The reservoir isn't leaking as I filled it to the brim and left it overnight. It was still full in the morning.
    The windscreen washer pump works fine.
    Is it an easy job to replace the sensor, or is it a whole new reservoir assembly?
  2. Re: Low Washer Fluid warning on permanently. Where is sensor located?
    May 2008
    You can replace the sensor on its own but if its an 08 car surely you should take it back under warranty?
  3. Re: Low Washer Fluid warning on permanently. Where is sensor located?
    Mar 2008
    Hi Issac,
    Just thought if the sensor was easy to get to, I could take a quick look and see if a gentle tap or quick fix might bring it back to life.
    Anything else and I will get it into the dealer for them to sort out!!!
    Cheers,
    Tony
  1. Washer fluid warning light
    By mak81 in forum Golf MK5 - 2004 - 2009
    Last Post: 07-02-2008, 01:44 PM
  2. air bag warning light permanently on
    By powerbike in forum Octavia
    Last Post: 23-11-2007, 04:25 PM
  3. windscreen washer fluid low warning
    By sbt in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 24-10-2007, 03:37 PM
  4. Washer fluid into car
    By Sky in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 26-03-2007, 12:43 PM
  5. Airbag Warning Light Permanently On
    By Paul Sharan in forum Touran - Sharan - Caravelle
    Last Post: 26-01-2007, 07:55 PM
