Thread: "How to Safely Clay Your Car Guide"
Page 1 of 3 123 LastLast
Results 1 to 10 of 24
  1. "How to Safely Clay Your Car Guide"
    Aug 2008
    Hi all,
    I have started this new thread so that I could talk to you about the importance of claying your cars. :thumbs:
    We will be ultimately talking about paintwork contamination and how to remove this from your precious 911.
    The majority of paintwork contamination consists of tiny metallic particles. These particles normally come from the trains (wheels & brakes) as well as normal cars. The tiny bare metal particles are extremely hot and normally found in the air nearer the train tracks. They are basically exposed to the air during the braking of cars and train. Slowly but surely they manage to find their way imbedding themselves into the paintwork of our cars. This is often the case on brand spanking new cars before they even reach the dealership!
    The above is a more severe form of paintwork contamination but extremely common.
    Tree sap is also a common problem along with general industrial pollution.
    On darker vehicles it is normally more difficult to spot the tiny bare metal filings but you can definately feel them. On lighter cars you can often see these particles and are normally brown. They are brown because they have basically oxidized and rusted into your paintwork. :nooo:
    By now you may be worrying that your brand new 997 is actually slowly rotting away. Well, don’t worry guys, there is a cure as to getting your car back to feeling silky smooth again.
    We need to basically perform a “clay bar treatment”.
    Ultimately it is possible to compound your cars paintwork to remove such impurities but this is the incorrect procedure. Compounding will also remove unnecessary clearcoat thus “cutting” into your paintwork.
    The best solution is a clay bar which will safely and effectively remove rail dust and industrial fallout by "pulling" it off the surface.
    It also does not “cut” into your paintwork and will not create any damage if used correctly.
    www.elitedetailer.com stock a clay bar called Zaino Z-18 Clay System and is pictured below:
    In addition to the Z-18 Clay Bar you will need to use a lubricant. Here is an example of one: Meguiars Last Touch as seen here:
    You will also need to pour the Last Touch into an empty spray bottle, i.e Meguiars Last Touch Bottle and Spray Head
    HOW TO USE THE CLAY BAR
    Regardless of which mild clay bar you decide to use, it is imperative to use on a clean surface straight after washing your car. If there are any dirt deposits on your car then it is highly likely that you will scratch your paintwork while performing this procedure.
    1. To begin with you need to pull and need the clay bar to get it nice and soft. Once you have done this, we are then ready to begin. If you are working in colder conditions, you can help soften the clay bar by letting it soak in a warm glass of water.
    2. Spray the Lubricant solution onto the panel quite liberally. It is important to use enough lubricant as it is quite possible to lightly scratch the surface if under lubricated.
    3. Now with your clay bar, gentley rub onto the surface in back and forth motions. Work in 1ft squares and take your time. Keep gliding the claybar across the wet surface until you can feel it is all nice and smooth.
    This is illustrated below:
    4. Now with a clean Microfibre Towel wipe the surface.
    5. Now “re-need” by refolding and pulling to create a clean side of the clay bar ready for the next section and repeat step “3” on the next part of the panel. This can been seen again below:
    It is also wise to clay your exterior windows/glass as shown below on a Mercedes rear screen:
    The soiled claybar:
    It is important to to not reuse the clay bar once it has been soiled and I prefer to throw them away. When it is only slightly soiled it can be used to great effect on cleaning up wheels.
    Here is a picture of a clay bar which has been soiled. The example shows the level of dirt which has come off a 2004 996 GT3 in Guards Red:
    Performing this process will not only make your car feel a lot smoother but in many cases enhance the appearance. It is also an important step before paint correction or any polishing is performed.
    The clay bar is great for use on glass as well as the paintwork, especially in the corners of the windscreens where so often there is a build of dirt.
    You can also use it to remove imbedded dead flies from the front of your vehicle including the wing mirrors as shown below:
    With regards to how often do you need to clay, well in most case twice a year is more than adequate.
    Although this process is recommended on all cars of all ages, it is even a more worthwhile procedure for cars which kick up a lot on the rear end of the car.
    Below is a simple diagram I have knocked up to illustrate what claying can do for your vehicle. Hopefully you will get the general gist of it.
    Here is a list of the products which can be used for the above process:
    Sonus SFX Clay Sampler Kit A Beginners Clay Bar Kit example
    Meguiars Clay Kit
    Meguiars Last Touch
    Spray Head
    Microfibre Towels
    Detailing Clay Section
    I hope this guide is helpful for you all. :thumb:
    Regards
    EliteDetailer :thumb:
    3 1 0
  2. Re: "How to Safely Clay Your Car Guide"
    Pembrokeshire
    22 Post(s)
    never knew there was so much involved in car care. will be in touch in the new year i think, as i would like to get my coupe gleaming again.
  3. Re: "How to Safely Clay Your Car Guide"
    Nov 2008
    West London
    Roughly how often would a car need to be clayed?
  4. Re: "How to Safely Clay Your Car Guide"
    Aug 2008
    Quote Originally Posted by Autostadt View Post
    Twice a year is normally adequate.
    EliteDetailer
  5. Re: "How to Safely Clay Your Car Guide"
    Stafford, Midlands
    i got a clay kit, didnt need any insruction as its pretty obvious how to do it, came up with an excellent finish on a ten year old car. i would reccomend it, its very very easy, just do it inside the garage if you have enough room, in the shade if not
    Subaru broken, sold, Silver Seat Leon Cupra 180 '02' no cupra badge?
  6. Re: "How to Safely Clay Your Car Guide"
    Nov 2008
    West London
    Quote Originally Posted by hongkongstuey View Post
    Was that on the Passat and how long did it take you?
  7. Re: "How to Safely Clay Your Car Guide"
    Stafford, Midlands
    was my old fiesta zetec, took a couple of hours, when the warmer weather comes along i'll do the passat, probably in a month or so, not doing it in the summer as not got a garage or enough shade, my fiesta hadnt been cleaned in months and after a 2 bucket clean and dry, it was clayed to within an inch of its life came up mint, hadnt been polished in 4 years roughly, knew the previous owner
  8. Re: "How to Safely Clay Your Car Guide"
    Dec 2007
    London/Surrey
    i got an ibis white A3. (new) and on my first day of collection there was these orange spots. Looked like rust! Used the clay bar and it easily came off. There are some spots left on the car, but i didn't bother doing them. I just took the large patches off.
    Also you must re-wax the car after clay-baring! So choose a warm/cool sunny/cloudy day. If in the sun do it in shade. I would also say the bumper and bonnet gets most effected.
    If you run of out the clay bar spray you could just use very soapy water (shampoo/wax as lubricant) Although i prefer the one in the bottle.
    COMING SOON: '14 A5 Cabriolet S-line Special edition, Daytona Grey
    CURRENT: 11' A5 S-Line Black Edition Ibis White
    previous: 09' A3 S-line Ibis White
  9. Re: "How to Safely Clay Your Car Guide"
    curiousgeorge Guest
    Thanks for this, I have some questions:
    What if I can't feel any bumps when I run my finger over the paintwork? Does that mean it doesn't need claying?
    What if I never clay my car?
  10. Re: "How to Safely Clay Your Car Guide"
    Jul 2007
    Cheshire, or my A6
    Claying is not only to give the paintwork a nice texture, but it removes swirls. So if your car has swirls then it needs claying. Without a clay, over the years the swirls may build up.
    2003 Audi A6 1.9 TDI SE Sport. Blue. Black leather interior, sport pack, 17" 9 spoke alloys, Concert II HU, grey aluminium inlays, rear boot lip spoiler, S3 mirrors, CD changer, black leather arm rest & more.
    2004 VW Transporter T5 1.9 TDI SWB van. White. 16" Tangis alloys, front fogs, chrome buzz bars, Caravelle tail lights, CD changer, tow bar, roof rack, signwriting & more.
  1. A "Community" a "Club" or a "Technical Forum"?
    By stuart in forum Chat - Completely Off Topic
    Last Post: 07-03-2009, 02:11 AM
  2. suspension arm "How to" guide anyone?
    By jemthetaxi in forum Passat - B5 Forum - 1997 -2005
    Last Post: 30-03-2008, 10:01 AM
  3. How do I "safely" increase my boost?
    By DubDick in forum The Commercial Range
    Last Post: 27-09-2007, 05:27 PM
  4. "How To" Post your "Detailing" Guide here
    By stuart in forum "How To" Guides
    Last Post: 05-08-2007, 09:41 PM
  5. Amusing "tourist video guide" to Torquay
    By devonutopia in forum Chat - Completely Off Topic
    Last Post: 07-01-2007, 04:07 PM
