Thread: Braking vibration but not discs.
  1. Braking vibration but not discs.
    Our new 03 Sharan is great except it vibrates under braking at high speed. I assumed it was the discs and changed them but the fault is still there.
    The discs I took off looked also brand new so I am guessing the previous owner tried the same thing. The tracking is fine and there is no knocks even over large bumps so I am a little confused, any ideas......
  2. Re: Braking vibration but not discs.
    7 Post(s)
    Failing flat bush on the lower arm(s) I'd say.
  3. Re: Braking vibration but not discs.
    1841 Post(s)
    Yes probably lower arm bushes but who is to say it is not a warped hub? I would do a disc run out check using a dial gauge.
  4. Re: Braking vibration but not discs.
    OK I think I will change the lower arm bushes on the front then. There are a lot of front arm rear bushes on various websites but no one lists the front bush, am I right in assuming then it is the rear bush that cause a problem on the front or do I need the front one of a dealer as well?
    Cheers for the replies........
  5. Re: Braking vibration but not discs.
    1841 Post(s)
    There are other ways of buying parts than ont tinterweb, such as from a VW dealer where you can step into a “shop” and speak to a “person” (OK, OK, we are talking VW dealer spares departments here!!), 7M0 501 541, £9 each front bush and 7M0 407 181 A £15 each rear bush,
  6. Re: Braking vibration but not discs.
    Thanks Crasher, for £9 a side I will change them anyways and let you all know.
    Thanks again for your time.
  7. Re: Braking vibration but not discs.
    1841 Post(s)
    It is normally wishbone rear bush that causes problems.
  1. Squealing when braking
    By kelvchan in forum Passat - B5 Forum - 1997 -2005
    Last Post: 03-03-2008, 10:36 AM
  2. Braking issues
    By jonathanp in forum Passat - B5 Forum - 1997 -2005
    Last Post: 31-01-2008, 12:35 AM
  3. Courtesy light and vibration on braking
    By Dabj in forum Golf MK4 - 1999 - 2004
    Last Post: 28-11-2007, 10:50 PM
  4. Golf mk3 GTi steering vibration when braking.
    By johnpatmos in forum Golf MK3 - 1993 - 1999
    Last Post: 12-08-2007, 10:39 PM
  5. Serious Braking Problem
    By rapster01 in forum Archive posts
    Last Post: 03-03-2007, 11:07 PM
