Thread: Reset Service Clock
  1. Reset Service Clock
    Feb 2007
    Hello All
    I have a Passat 1.9 TDI 2001. I recently had a service come up and reset the service clock while it was on 'SERVICE NOW' and then serviced it at a local garage.
    Unfortunately the service clock has not reset to the milage it was supposed to , it is stuck on 'SERVICE NOW'.
    Can any one tell me how to reset the service clock and specify my own milage. It will cost me £18.00 at the dealership for a 15 min job.
    Thanks in advance for any advice.
    Naheem.
    Oct 2005
    Feb 2007
    Unfortunately I have a VW Passat 2000 and it does not display the "IN01" or "IN02".
    It is a digital odometer but does not work as per the instructions listed in the thread.
    Do you have any more ideas.
    If not then I think it maybe a dealership job.
    Thank you.
    Naheem
    May 2006
    Exmouth, Devon, UK. Drives Bonkers Fabia Diesel. Has full VCDS
    I did a quick google and came up with this
    vehicles on fixed interval servicing can be reset as follows
    Press and hold button "A" (positioned right of trip recorder display)
    Switch ignition ON
    The word "SERVICE" will appear in the trip recorder display
    Release button "A"
    Turn button "B" (positioned left of trip recorder display) to the right to reset the display
    Switch ignition OFF
    Please let me know if this works.
    Jason - Rather mad Skoda Fabia driver.... Odd whiff of diesel coming from him.
    260bhp Skoda Fabia TDI Dyno Run
    http://www.youtube.com/watch?v=9BvjJjL7Z50
    315bhp Skoda Fabia TDI Dyno Run (2013)
    http://www.youtube.com/watch?v=TOE4nbT5NGY
    Feb 2007
    Hello
    Sorry but no luck with releasing button A and then turning B to the right.
    I'm going to phone the dealership and ask them first to tell me how to do it. It's a long shot but its way cheaper then £16.
    I'll let you know how it goes. Also the instructions in the hand book are wrong for resetting the service clock and there is a warning about not letting the clock zero out or showing 'SERVICE NOW'.
    Will post back my findings.
    Thanks all
    Naheem
    Feb 2007
    Hi All
    Well I finally spoke to the dealership and they told me it depends on what type of service the clock is set to. If it is long term then it has to be done by computer.
    If it is done by time and distance then you can adjust the clock your self. Unfortunately mine is long term service.
    I have booked it in to change the clock to Time and Distance so that I can change it later.
    Hope this helps
    Thank you for your help
    Naheem
  1. Service Indicator Reset
    By pbriggs in forum Passat - B5 Forum - 1997 -2005
    Last Post: 16-04-2018, 12:47 PM
  2. Service light reset
    By Sony in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 29-09-2009, 10:19 PM
  3. Service Reset
    By stevenrmartin in forum A2
    Last Post: 10-02-2008, 07:50 PM
  4. How to Reset Service Warning?
    By mxt8397 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 10-03-2007, 12:09 PM
  5. SERVICE RESET?
    By vroooOOOM in forum Passat - Archive Topics
    Last Post: 01-12-2006, 02:58 AM
