Thread: Engine Coolant Temp Sensor - where?
  1. Engine Coolant Temp Sensor - where?
    OK I have now purchased the sensor, and took a quick look under the bonnet today. I found several sensors which could be the right one, but I am not 100% sure and I dont have a Haynes manual. A blue one down by the passenger side coming off the side of the rad? or one not sure what colour off the top of the engine.
    Can someone point me in the right direction. I have read on the internet that its on the drivers side coming of the top of the head gasket. I have also read that it requires a full change of coolant and bleed the system. Found some pics but its from an audi A4 are they similar?
    I have a passat B5 130tdi.
  2. Re: Engine Coolant Temp Sensor - where?
    Hi The sensor is on the right hand side and on the rear of the engine
  3. Re: Engine Coolant Temp Sensor - where?
    Quote Originally Posted by kenney View Post
    thats the drivers side then I take it?
    On the top of the rear of engine?
    cheers
  4. Re: Engine Coolant Temp Sensor - where?
    Drivers side yes.It is the only sensor in that area,a connector with 4 wires runs to it
    By clarky_two in forum Chat - Anything with wheels
    Last Post: 09-12-2008, 05:48 PM
  2. W8 coolant temp sensor
    By Pete Stecks in forum Passat - B5 Forum - 1997 -2005
    Last Post: 07-08-2008, 09:39 AM
  3. Engine Coolant Temp Sensor
    By doug.howsie in forum Passat - B5 Forum - 1997 -2005
    Last Post: 14-10-2007, 02:00 PM
  4. coolant temp sensor in APT 1.8 20v
    By redman in forum Passat - B5 Forum - 1997 -2005
    Last Post: 21-09-2007, 02:23 PM
  5. mk3 coolant temp sensor
    By pazur in forum Vento - 1994 - 1998
    Last Post: 05-08-2007, 05:53 PM
