Thread: vag com error code any ideas
  1. vag com error code any ideas
    Oct 2006
    bedfordshire
    Hi All
    Had my car looked at regarding a vag com fault code and was advised the
    problem is connected to the rear cam chain ajuster out of limits. To correct
    this the front end is to be removed cam belt and cams needed to be removed a new adjuster and h=then rebulid at a cost of around £675
    Have changed cam position sensor due to starting problems and changed the speed sensor.
    Can there be an adaption done to correct errors as I HAVE CHANGED BOTH SENSORS, or is be a top end rebuild as the garage states.
    The car is running ok my problem is the engie fault light is on constantly,when I run vag-com and clear the fault at comes back when driving and stays on.
    Fault code 17748 Camshaft position sensor (G40) / Engine speed sensor (G28): Incor. correlation.
  2. Re: vag com error code any ideas
    Magdeburg, Germany
    Sebastian @ www.Ross-Tech.com
  3. Re: vag com error code any ideas
    Bradford
    Having looked at the wiki link, why would you ever need to have the timing chain lengthened
  4. Re: vag com error code any ideas
    May 2008
    It means the timing chain may have already lengthened - I.E It has streched beyond its service limit.
  5. Re: vag com error code any ideas
    I was just about to suggest that the sensor itself is unlikely to be faulty, but the timing belt/chain.
    I had the exact same fault on my last car, when a garage failed to time it up properly, the cam position sensor picked this up and the rest is history....
    I'd be wary of just replacing parts without having checked that chain first.
  6. Re: vag com error code any ideas
    joe-9o Guest
    Quote Originally Posted by MCCLATCHIE View Post
    Hi All
    hope this helps;
    17748/P1340/004928 - Camshaft Position Sensor (G40) / Engine Speed Sensor (G28): Incor. Correlation
    Possible Causes
    Timing Belt/Chain incorrectly installed
    Timing Chain probably lengthened
    Camshaft Position Sensor (G40) faulty
    Engine Speed Sensor (G28) faulty
    Possible Solutions
    Check Timing Belt/Chain installation
    Use Measuring Value Blocks (MVB) to Check Timing Chain
    Check/Replace Camshaft Position Sensor (G40)
    Check/Replace Engine Speed Sensor (G28)
    Special Notes
    When found in the 1.8T engine, check engine oil pressure. The oil pump pickup may be restricted.
    When found in the 1.8T engine (possibly others too), check to make sure the correct G40 is installed (single gap versus 4 gap).
  7. Re: vag com error code any ideas
    Norfolk
    What car/engine/code ???
  8. Re: vag com error code any ideas
    joe-9o Guest
    HI Martin. the car is 2004 Audi B6 1.9 TDi Quattro Avant 130, PD engine. there is no fault code. the engine code is AVF, thanks , Dave
  9. Re: vag com error code any ideas
    Norfolk
    In that case most of the fault code possible causes are meaningless. The code is basically saying that the crank sensor and cam sensor don't agree with each other. As this engine is cambelt driven it means the cambelt has slipped or been fitted one tooth out. Another possibility is the cam has been removed and refitted 180 degree out. Has a new belt been fitted recently.
  1. Vag-Com error codes, any ideas for fix?
    By abbeyhouse in forum Archive posts
    Last Post: 05-06-2007, 11:30 PM
  2. mk4 gti 2.0, 3 error codes, lean trim, ideas?
    By leckford in forum Golf MK4 - 1999 - 2004
    Last Post: 24-05-2007, 11:57 PM
  3. Error code P1553
    By Fozmondo in forum Polo - Derby - Lupo - Fox
    Last Post: 15-05-2007, 08:25 PM
  4. VAG COM Error Code
    By rachykate in forum VCDS - General Questions
    Last Post: 04-04-2007, 10:19 AM
  5. OBD - Error Code Anyone know what this is
    By triman in forum Audi A4 - Archive Topics
    Last Post: 03-02-2007, 06:10 PM
