Thread: Rear Demister not working?
  1. Rear Demister not working?
    Hello All.
    My girlfriends 2003 golf tdi's rear window demister has stopped working, I have checked the fuse and its fine. Are there any other known issues with these things?
    thanks
    brian
  2. Re: Rear Demister not working?
    Dec 2008
    Hi Brian
    I've just bought a Mk4 with the same problem. It turned out to be a broken wire in the rubber boot where the wires come through from the roof to the rear hatch. I managed to re-connect the wire with a through-crimp. Don't know how long it will last though as it flexes every time you open or close the rear hatch.
    Regards
    Keith
  3. Re: Rear Demister not working?
    hello Keith, is it possible to get the rubber boot out of the way or did you need to damamge it to get a the broken wire?
    thanks
    bria
  4. Re: Rear Demister not working?
    Dec 2008
    Hi Brian
    Whilst you can't actually remove the boot completely, you can pull it out of the roof and put it back in quite easily. the hard part is joining the wire back up if it's broken. Mine was on the right hand side - the brown return wire. It's the thickest of the wires in there. The other wire on the left hand side is white.
    Regards
    Keith
  5. Re: Rear Demister not working?
    Hello There,
    Yes I checked the rubber boot on the right, the thick brown wire was snappped and also the green wire was snapped. I resoldered the green one and put the brown one in a connector. thanks for your help.
    Brian
  1. audi a4 : FM stereo lost when rear window demister on
    By mr_greenfelduk in forum In Car Entertainment
    Last Post: 02-03-2009, 01:07 PM
  2. Avant rear screen demister not working
    By AndrewS1 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 11-10-2008, 03:19 PM
  3. Replies: 1
    Last Post: 14-10-2007, 12:06 PM
  4. A4 Demister problem
    By scorpio in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 14-03-2007, 07:22 PM
  5. Rear demister fault
    By Marc97 in forum 80 - 90
    Last Post: 22-01-2007, 04:11 AM
