Thread: Handsfree parrot kit
  1. Handsfree parrot kit
    Nov 2008
    Hi guys
    Im struggling to understand which stereo setup i have in my A4 avant.
    Its a concert stereo, just cd no tape. On the back of it, it has 3 iso blocks.
    The top black one which is bigger than the other two below seems to power the back speakers and possibly the sub in boot side, the next one down (brown) does the front speakers and the last 1 (black) is the power block.
    Is this half bose? or not at all. I cant see a bose wire going into the black block at the bottom.
    The reason for all this is i have a Parrot CK3100 car kit. My work bought it for me and it was installed in my mk4 Golf anni, now i need to install it in the audi, but im not sure which car kit adaptor i need to buy for it.
    My options from parrot are:
    A4: 2001 – 2004, BOSE + Nav
    A4: 2001 – 2004, Nav. Plus
    A4: 2004-2007, Standart
    A4: 2004-2007, BOSE Syst.
    A4: 2004-2007 , MMI
    Now im guessing its one of the top two as its a 2003 car.
    Any help would be great?
  2. Re: Handsfree parrot kit
    Dec 2007
    Quote Originally Posted by A4TDiavant View Post
    Hi guys
    A4: 2004-2007 , MMI
    its standard half amped
  3. Re: Handsfree parrot kit
    Nov 2008
    Ok, so which parrot adaptor do i need?
  4. Re: Handsfree parrot kit
    Dec 2007
    what year is your car ?
    saloon or avant ?
    if avant have u got a sub in the right hand rear boot trim ?
    saloon sub under rear shelf ?
  5. Re: Handsfree parrot kit
    Nov 2008
    what year is your car ? 2003
    saloon or avant ? Avant
    if avant have u got a sub in the right hand rear boot trim ? Right hand boot trim
  6. Re: Handsfree parrot kit
    Dec 2007
    you need the standard.
    but i think you may have tio run a igg live to the unit as not all have it on my 02 avant i had to but not on the 04
  7. Re: Handsfree parrot kit
    Dec 2006
    Take a look at this thread i did.. "HOW TO" fit a NOkia Car kit.
    https://www.vwaudiforum.co.uk/forum/s...ight=NOKIA+car
    The thread takes a while to loads as there are loads of photos on there.
    If you go to the like of Halfords, you will be able to purchase some small Spade connectors which push onto the pins on the rear of the Head unit... (you just need to ensure you sheild them amd ensure they are connected tight..)
    You only need to connect the headunit to the mute, Speaker Left/Right, and tap the power from the fuse box of from the switch live.
    Thanks..
  1. Parrot Handsfree Kit
    By jkh112 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 24-10-2008, 04:00 PM
  2. Handsfree help?
    By Touchofclass in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 12-12-2007, 07:42 PM
  3. Parrot handsfree in '05 Mk5 2.0TDI
    By architect in forum Golf MK5 - 2004 - 2009
    Last Post: 07-12-2007, 07:56 PM
  4. what bluetooth handsfree
    By blacksline in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 19-07-2007, 10:23 PM
  5. Bluetooth handsfree
    By kiwibeef in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 25-04-2007, 06:43 PM
