Thread: gear ratios?
  1. gear ratios?
    south wales
    right then this is one for i guess anyone that has a 5 speed pd engined tdi
    just read that the 5 speed box is a higher ratio in 5th than the 6 speed box is in 6th!
    whats the point what were vw thinking off
    so can anyone tell me what there car reves at say 60 70 and 80mpg in 5th
    would just be interesting to see what the difference is on my 6 speed
  2. Re: gear ratios?
    Jun 2006
    UK, Mids
    If you know any one of those speeds, you can work out the other two easily enough as it is proportional
    e.g. If 60mph = 2000rpm then 70mph = 2333rpm (70/60 x 2000)
    Audi A8 - 2015 - 3.0TDI
  3. Re: gear ratios?
    Quote Originally Posted by minty0_10 View Post
    Its just over 2000 in 5 th at 60 mph, makes it perfect for the motorway giving 60+ mpg but still loads of torque for overtaking.
  4. Re: gear ratios?
    Got a 6 speed box Passat tdi 130 sport, 6th gear at 60 gives 1900 rpm.
  5. Re: gear ratios?
    south wales
    yes thats what mine does i was asking as someone on here posted that the 5 speed box was a higher ratio (ie lower reves) than the 6 speed is in top
    seems not to be through.
  1. 2.0tdi Sport gear ratios and worst mpg?
    By d_onions in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 03-11-2008, 06:03 PM
  2. Gearbox Ratios
    By mgouldstone in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 12-04-2008, 08:52 PM
  3. Gerbox Ratios
    By mgouldstone in forum Passat - B5 Forum - 1997 -2005
    Last Post: 06-04-2008, 04:38 PM
  4. Gear ratios
    By peterwatkins99 in forum Bora - 1998 - 2005
    Last Post: 04-09-2007, 09:46 PM
  5. Audi 80 TDi gear ratios
    By andymc in forum 80 - 90
    Last Post: 26-03-2007, 05:10 PM
