Thread: Crank case pressure !!
  1. Question Crank case pressure !!
    Nov 2008
    Just paid 500 Quid for a 1996 1.8t avant to get about as the gearbox on my tdi has just exploded!!
    It has high pressure in the crank case but runs ok .
    Ive heard that you can get a modified breather kit ? is that true and would this solve the problem or is it something worse ??
  2. Re: Crank case pressure !!
    1837 Post(s)
    If there is high pressure in the system then no breather mod will help. What are the symptoms, blowing oil into the intake?
  3. Re: Crank case pressure !!
    Nov 2008
    Just got it today will check it tommorrow bit of dirty oil round filler cap aswell
  4. Re: Crank case pressure !!
    1837 Post(s)
    That’s normal but they do sludge up inside, removing the cam cover and flushing it out as well as the sump (big job) is a very much recommended job.
  1. CVT complaint case - I won!!!
    By a4_jim in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 25-10-2008, 04:28 AM
  2. AAT/AEL New crank or re-grind???
    By philbarber in forum 100 - 200 - Turbo - 100 S4
    Last Post: 26-03-2008, 11:04 PM
  3. 02 a4 3.0l crank no start
    By matt9129 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 23-12-2007, 11:23 PM
  4. VR5 Crank Sensor...
    By suisideg60 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 04-11-2007, 11:14 AM
  5. Crank Sensor?
    By my1stGTi in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 27-04-2007, 08:58 PM
