Thread: Losing Brake Fluid!!! Advise Please
Results 1 to 8 of 8
  1. Losing Brake Fluid!!! Advise Please
    Mar 2008
    Hello, I recentyly noticed over the weekend that im losing wuite a bit of brake fluid but i have not got a clue where the leakage is coming from. Could it be possibly from one of the copper pipes or is there a way you can check to see where its leaking from. I toppped over the wkend just over the min level and checked today to find out its quite below the min level.
    Any advise ld be greatly appreciated.
  2. Re: Losing Brake Fluid!!! Advise Please
    Hi Have a look at the rear brake calipers,there are washers on the brake hoses,which tend to corrode,and can leak
  3. Re: Losing Brake Fluid!!! Advise Please
    Pembrokeshire
    22 Post(s)
    get someone to stand on the brake pedal, whilst having a check of your calipers and pipes. if its not as kenney suggested, it could be any pipe or flexi hose leaking.
  4. Re: Losing Brake Fluid!!! Advise Please
    Mar 2008
    cheers guys. found out its from the master cylinder. the seals re won. can u get replacement seals for it. or do I ve to get a new master cylinder
  5. Re: Losing Brake Fluid!!! Advise Please
    Dec 2008
    You can rebuild a master cylinder if you want - there are places online that can supply you all the fiddly little bits you need.
    However I'm lazy and have really fat fingers so I'd be tempted to buy a new one (if I were you I'd steer clear of 2nd hand brake parts - or hopefully obvious reasons!)
  6. Re: Losing Brake Fluid!!! Advise Please
    Mar 2008
    cheers for that. U got any links where i can get the fidly parts from
  7. Re: Losing Brake Fluid!!! Advise Please
    Dec 2008
    http://www.biggred.co.uk/cylinderrepairshop.html
    Give these guys a buzz - I've heard very good things about them...
  8. Re: Losing Brake Fluid!!! Advise Please
    Pembrokeshire
    22 Post(s)
    i wouldnt even try to rebuild it personally. its probably leaking due to corrosion inside the bore, which wont be cured with new seals. it may alleviate the problem for a while, but will probably leak again. a new one wont be that dear from somewhere like gsf. it would also be worth taking the servo off and draining any fluid from there, presuming its been leaking into the servo.
  1. Brake fluid
    By howardpigott in forum Audi A3 - Archive Topics
    Last Post: 09-01-2008, 10:48 AM
  2. Renew your brake fluid with OEM spec fluid!!!
    By cbrpaul in forum Chat - Anything with wheels
    Last Post: 01-10-2007, 01:54 PM
  3. Brake problem..advise
    By basoom in forum Passat - Archive Topics
    Last Post: 21-08-2007, 09:31 PM
  4. brake fluid
    By clint in forum Passat - B5 Forum - 1997 -2005
    Last Post: 08-06-2007, 05:33 PM
  5. Brake fluid - dot 4 or 5.1?
    By wid77 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 13-03-2007, 10:10 AM
