Thread: Windscreen washer jets not working!
Results 1 to 10 of 13
  1. Exclamation Windscreen washer jets not working!
    May 2008
    Hi all,
    What is about these bloody Passats. It is the newest car I have ever had and the most unreliable so far. I love it, but it is starting to frustrate me.
    This weeks problem is the windscreen washer jets.
    At the weekend they did not always respond to a "pull" on the stalk, (The head light washers are perfect though) Now today, they windscreen washers do not work at all.
    The rear washer / wipe is fine
    The headlight wash is fine
    The windscreen wipers work fine though.
    The Haynes book of lies tells me the front and back work off the same pump, but that does not make sense to me as you cannot hear the pump "whirr" if you wash the windscreen, however it all works on the rear
    Can anyone shed any light please?
    Cheers,
    Steve.
    2001 B5 Passat Estate 130TDI Sport, Audi S2 Coupe, Audi 80 Sport Edition.
  2. Re: Windscreen washer jets not working!
    Quote Originally Posted by Fat Audi 80 View Post
    Hi all,
    Cheers,
    Steve.
    Take the pumps out of the reservior and clean it really well, flush the pumps and check them, its probably gunge got into change over valve!
  3. Re: Windscreen washer jets not working!
    May 2008
    Quote Originally Posted by caldirun View Post
    So are you saying there are two pumps?
    I cannot hear a pump running for the windscreen, but one runs for the rear window...
    I am still confused.
    Cheers,
    Steve.
    P.s. what is the changeover valve???
  4. Re: Windscreen washer jets not working!
    Cheers,
    Steve.
    If a pump was blocked and could not turn, would you hear it running?, it could be a single pump with 2 outlets and a change over valve for front or rear wash according to run direction.
  5. Re: Windscreen washer jets not working!
    Jun 2006
    UK, Mids
    Looking at the parts diagram and lists, it seems to suggest that there is only one pump assembly for the rear and front washers (two pumps in one unit), but a completely different bottle and pump for the headlights. Maybe it is even the wash/wipe relay. Getting to the pump is really hard.
    Audi A8 - 2015 - 3.0TDI
  6. Re: Windscreen washer jets not working!
    May 2008
    Quote Originally Posted by snapdragon View Post
    Thanks Snapdragon, that is more what I was looking for, facts or confirmation of fact/theory.
    I think I need to investigate the relay. I am convinced the switch is working as the headlamp washer still fires. I am working my way through the wiring diagram in the Haynes manual, which is much better than their old ones but still fairly difficult going for a mechanical engineer!
    I will post up when I get some further news.
    Cheers,
    Steve.
  7. Re: Windscreen washer jets not working!
    Chester-le-Street, United Kingdom
    has it just stopped with the recent cold weather?
    is it not just the front jets frozen?
    my van has been frozen up all day today,mind the jets are half way down the bonnet
    and the wind chill factor will affect them.
    first time i was up a ladder i was down a well
    4th cog,--two to go
  8. Re: Windscreen washer jets not working!
    Cheers,
    Steve.
    You should have said you were a mechanical engineer, sorry.
    Take the fuse out, put the multimeter prongs into the fuse receptacles, set the meter on Amps DC, range above the fuse rating, wash rear, make note of reading, wash front, make note of reading, post for instructions!
  9. Re: Windscreen washer jets not working!
    Hi all,
    Cheers,
    Steve.
    The Haynes shows the saloon set up with one wire to ground on the pump, the estate probably has 3 wires, pump fwd, pump rev, ground, or 2 wires both connected back to the relay (so each wire can be +ve or ground). If you check the diagram there are 2 outlet fittings on the pump, if the pump runs fwd it turns the impeller which rotates the stator and delivers water to the one fitting (maybe the front washer jets),.If the pump runs rev, the impeller turns the stator in the opposite direction delivering water to the other fitting, hey presto, one pump 2 points of delivery.
    The stator can get gunged up and stop rotating, clean the reservior and filter (sorry but its a hands on job). I just called it a change over valve to simplify things!
    This is theory as I have a saloon
  10. Re: Windscreen washer jets not working!
    Verwood, Dorset
    It is a bumper off job to get to them. I have a saloon, and there are two pumps on my reservoir. One for the headlamp washers and one for the windscreen.
    To remove the bumper there are three screws in each wheel arch, and then you take off the trim with the VW badge on, and there are some Torx screws under that. You will also need to undo a bolt or two under the front of the car.
    To me it sounds as if you have a bad connection. Perhaps one of the connectors pins is corroded, as the others say it is a bi-directional pump, so one of the supply pins may need a clean..
    Tom.
    See you in my smoke...
  1. Washer Jets
    By Moro Anis in forum TT - 8N Forum - 1998 - 2006
    Last Post: 21-04-2008, 01:45 PM
  2. Washer jets.
    By Millerman in forum 80 - 90
    Last Post: 25-03-2008, 06:55 AM
  3. Heated Washer Jets for Windscreen
    By Polo Mint in forum Polo - Derby - Lupo - Fox
    Last Post: 21-02-2008, 05:12 PM
  4. Heated washer jets not working.
    By BenR in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 22-12-2007, 11:18 AM
  5. Heated windscreen washer jets?
    By Zub in forum Passat - Archive Topics
    Last Post: 02-03-2007, 04:55 PM
