Thread: Front Passanger Door Central Locking Problem
  1. Front Passanger Door Central Locking Problem
    Apr 2007
    I have got a 2001 sport estate and the front passenger door can't be locked using the driver door switch. It closes momentarily and then pops up again. I can manually push the button down. Strangely no problems locking the car with the fob. Any idea what it could be?
    I did change the window glass in the door 6months ago, could I have disturbed something then...........don't know if this is a new problem or I have just discovered it now.
    Any help much appreciated
  2. Re: Front Passanger Door Central Locking Problem
    Apr 2007
    warrington
    sounds like theres a cable trapped some were could have happend when you put the door card back on its does happen make sure all the cables are in the right place try the door lock with the door card off see if that works if you need any advice just give me a shout
  3. Re: Front Passanger Door Central Locking Problem
    Apr 2007
    Thanks for the suggestion guess will have to have a go it, but don't you think it's strange that there is no problem when I use the key fob to lock the door, after all it's the same mechanism being used!
  1. Replies: 8
    Last Post: 19-08-2009, 09:23 PM
  2. Stuck door problem, central locking problem & no alarm
    By andyaudia4 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 26-11-2008, 05:57 PM
  3. Central Locking Not Locking Drivers Door
    By davieb in forum Passat - B5 Forum - 1997 -2005
    Last Post: 06-11-2008, 10:37 PM
  4. Please Help Passat B5? Central Door Locking Problem
    By sleezeydog in forum Passat - B5 Forum - 1997 -2005
    Last Post: 08-07-2008, 04:45 PM
  5. Central door locking problem! Boot wont open! Please help!!!
    By MiniMadTez in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 05-08-2007, 10:19 PM
