Thread: Help updating MMI software Nav system
  1. Help updating MMI software Nav system
    Aug 2008
    Hey guys, I have recently purchased an Audi A5, and i have downloaded the latest 5150 mmi ugprade discs. But i cant seem to find out what the upgrade does other than give me 3D view.
    Also, am i correct in saying i place the disc in the cd player to upgrade?
    Also can i just jump to 5150 version, without needing to update to the previous versions first? I ask this, because, the previous versions are bigger files.
  2. Re: Help updating MMI software Nav system
    Dec 2006
    Wiltshire
    That's not the right software for an A5.
    A6 (2007)TDi SE Avant
    Gone but not forgotten - A4 2.5TDi Avant, Imola Yellow S3 , Golf VR6 Highline
  3. Re: Help updating MMI software Nav system
    May 2007
    knee deep in clunge
    14 Post(s)
    You need cd rom 8K0 906 961 AND THEN 8K0 906 961 A.But why bother when the dealer will do it for you foc and also run a sw update check to the vag server.
    if you insist on playing read on http://audiforum.us/mmi/6780-new-eu-...rs-5150-a.html
  4. Re: Help updating MMI software Nav system
    Sep 2018
    alajuela Costa Rica
    not trying to steal this tread but i have a few questions on my new 2018 Q5. i ordered it without Nav as a base model car. and the MMI is on version MST2_EU_AU_P9118D, MU software 0840. i seem to be missing a lot of items in my MMI and car that are supposedly included per the manual in the glovebox.
    there is no APPLE CARPLAY and that is why I deleted NAV as i wanted to use WAZE via the iPhone.
    the cruise control works as a speed limiter but not as a cruise. you can only set a speed above which the car will not go using the gas pedal. useless to me
    the rear view mirror on the passenger side does not drop down to see the curb in reverse as my 2008 A4 does or my last 2013 Q5 did. i try to set it using the audi procedure i found on line but no luck.
    using Audi connect via a cable to the iPhone i cannot access playlists and sometimes if i used bluetooth then switch t cable the phone says stuck on one song and neither the phone or the volume joystick in car can change it.
    are these things available on the hidden menu or do i have some reduced version MMI software>
    thanks
    Richard
  1. Question EGR System for TDI's - Keeping intake system clean
    By Audichap in forum Leon
    Last Post: 12-10-2008, 12:19 AM
  2. updating a3 lights
    By jonnyparker in forum New Member Introductions
    Last Post: 02-08-2008, 04:50 PM
  3. Updating and connecting a Sat Nav RNS-E
    By deviseruk in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 03-01-2008, 12:38 AM
  4. Updating the ECU map
    By James H in forum Archive posts
    Last Post: 25-10-2007, 10:44 PM
  5. Can You Update the A3 CD-ROM Sat Nav System Software?
    By TFT_Warrior in forum Archive posts
    Last Post: 17-10-2007, 10:14 AM
