Thread: Golf 1.6 SE 8 Valve Running lean
Results 1 to 10 of 11
  1. Cool Golf 1.6 SE 8 Valve Running lean
    Sep 2007
    Hi, first post here.
    My golf is a 1.6, 8 valve and has had a lot of work done on the engine and it still runs like siht!!
    Here is what has been done:
    new head gasket,
    new pistons,
    new inlet manifold
    new oil filler neck
    new throttle body
    new mass air filter
    new camshaft sensor
    new lambda probe
    and all the fault codes for these problems have been reset.
    It still runs very sluggish. Some days it runs great with full power, but soon as the temp gauge hits 90 it goes sluggish again. But the majority of the time it runs sluggish. 2nd gear also seems to be quite flat out of all the gears.
    I have spent a stupid amount of money on this car and therefore would like to know what the problem is. I don't really want to sell it at the moment as I can't afford to buy another car with the credit crunch etc.
    Please help!!
    Any suggestions to what it could be, would be much appreciated and fantastic if it can solve the problem.
  2. Re: Golf 1.6 SE 8 Valve Running lean
    Hi perhaps a stupid question,but have you checked the basics,compression,timming,etc?
  3. Re: Golf 1.6 SE 8 Valve Running lean
    Sep 2007
    Quote Originally Posted by kenney View Post
    Hi there, erm.. Im not sure, my mechanic should have but he has not mentioned anythin about it. I will ask him and get back to you.
    Thanks for a speedy reply.
    By the way is there any way I can do this myself or do I need Vag com??
  4. Re: Golf 1.6 SE 8 Valve Running lean
    Chester-le-Street, United Kingdom
    i believe the throttle body has to be "matched" to the ecu electronicaly.
    perhaps this was overlooked?
    regards,
    stewy.
    first time i was up a ladder i was down a well
    4th cog,--two to go
  5. Re: Golf 1.6 SE 8 Valve Running lean
    off thread,but, i see i have been "thanked in one post"
    is their an easy way to find out which post and by whom?
    thanks,
    stewy.
    4th cog,--two to go
  6. Re: Golf 1.6 SE 8 Valve Running lean
    Sep 2007
    Quote Originally Posted by STEWY L View Post
    regards,
    stewy.
    Yea my mechanic said that when I drive the car, the throttle body should automatically configure itself to the ecu.
    Is that correct or is he chattin bubbles?
  7. Re: Golf 1.6 SE 8 Valve Running lean
    Dec 2007
    Suffolk
    Has the live data from the coolant temp sensor been checked?
  8. Re: Golf 1.6 SE 8 Valve Running lean
    Quote Originally Posted by obx102 View Post
    i think he is mistaken,i'm sure i have read that it needs to be done electronicaly.
    stewy.
    4th cog,--two to go
  9. Re: Golf 1.6 SE 8 Valve Running lean
    Sep 2007
    Quote Originally Posted by smokey0123 View Post
    I couldn't tell you to be honest,
    all the suggestions I get from all you very helpful people are going to be brought forward to my mechanic.
    It seems like he's not been doing his job!!
    Please keep coming with the suggestions, I am very grateful!!
  10. Re: Golf 1.6 SE 8 Valve Running lean
    1836 Post(s)
    What is the year and engine code, 1998 to 2000 ish and AKL? If it is running poorly, it should be generating a fault code.
  1. Please Help S3 Fault - Fuel too lean
    By AK30 in forum Audi A3 - Archive Topics
    Last Post: 23-07-2008, 07:59 AM
  2. Please Help MK3 ABF Running too Lean
    By Golf-Fiend in forum Golf MK3 - 1993 - 1999
    Last Post: 09-05-2008, 05:50 PM
  3. (Mult) System too Lean - 17536 - P1128
    By dm.A4.B5 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 31-10-2007, 08:35 PM
  4. S6 "Left bank running lean"
    By toff in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 13-08-2007, 01:42 AM
  5. mk4 gti 2.0, 3 error codes, lean trim, ideas?
    By leckford in forum Golf MK4 - 1999 - 2004
    Last Post: 24-05-2007, 11:57 PM
