Thread: Help - Guys I need some IT help
Results 1 to 9 of 9
  1. Help - Guys I need some IT help
    Jul 2008
    It sounds simple but I have not been able to find a solution yet. I have a spreadsheet which I have been just adding friends and contacts other the years and now feel I need to automate.
    Is there anyway of transferring 1400 contact directly to a database without entering 1 by 1. I have been searching on the net for the last few days and have not been able to find anything.
    Thanks for any help!
  2. Re: Help - Guys I need so It help
    Oct 2005
    http://databases.about.com/od/tutori...eltoaccess.htm
    Go nuts!
    Let me add more to this - the above is for 2007, most don't use it because the layout sucks
    Depending on what version of Excel/Access/DB program you have, there's an option within Excel (whatever you use) to save the data as a DBF file.
    Then you open it in your favourite database app and off you go.
  3. Re: Help - Guys I need so It help
    Jul 2008
    Go nuts!
    I am using 2003 found option to tranfer data but still does not complete.
  4. Re: Help - Guys I need so It help
    Oct 2005
    Quote Originally Posted by ashadam View Post
    I use 2k3 too.
    What, if any, error messages are you getting? I'll give it a go a bit later on and see if I can make it work
  5. Re: Help - Guys I need so It help
    Mar 2008
    High Wycombe
    Wouldn't it be better to use a proper contact management tool? Something like the contacts section of Outlook / Thunderbird.
    You could then just export your excel sheet to a .csv file, and import that into your contact manager.
    I keep all mine in my palpilot, which replicates with my PC, so I have the info on me, and backed up on my PC.
    If you do want to import it into access, then a simple File-Get External Data-Import should be able to read it directly from Excel and put it into a new table.
    2002 Passat 1.9tdi
    2004 A3 2.0 FSI
  6. Re: Help - Guys I need so It help
    Mar 2008
    High Wycombe
    If you have problems getting it into access, I'll offer to import it for you, although I'm only using access2000
    2002 Passat 1.9tdi
    2004 A3 2.0 FSI
  7. Re: Help - Guys I need so It help
    Jul 2008
    I use 2k3 too.
    I have managed to import but has come over as one field so address still all in on file not individual.
  8. Re: Help - Guys I need so It help
    Oct 2005
    Nick makes a good point there.
    Exporting it as a CSV and then importing into Thunderbird/etc would be a much easier method
  9. Re: Help - Guys I need some IT help
    Jul 2008
    Below is the format the text is enter into excel. The spreadsheet is no formulated.
    1X
    2XXXX3XXXX4XXXX5XXXXXXX6XXXXXXX7XXXXXXX8XXXXXXXXX9XXXXXXXXX1011XXX12XXXXXX13XXXXXX14XXXXXXXXXX15XXXXXXXXXX16XXXXXXXXXX17XXXXXXXXXX18XXXXXXXXXX19XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
  1. What you guys think of this???
    By Antonio Pais in forum Bora - 1998 - 2005
    Last Post: 07-06-2008, 09:40 AM
  2. Hi guys
    By damk in forum New Member Introductions
    Last Post: 21-05-2008, 04:03 PM
  3. Hi Guys, please help
    By keithchalm in forum New Member Introductions
    Last Post: 13-05-2008, 07:49 PM
  4. hey guys
    By silentplayer in forum New Member Introductions
    Last Post: 09-02-2008, 09:46 PM
  5. Hi guys
    By k9max in forum New Member Introductions
    Last Post: 06-10-2007, 02:04 PM
