Thread: Heater matrix - no hot air!!!
Results 1 to 10 of 12
  1. Heater matrix - no hot air!!!
    Dec 2006
    Guys,
    I have got no hot air...... i have been away for a week, got into the car and all appeared fine.... as i have been out in -30'c conditions, i wacked the aircon on "LO" as i was red hot!! anyway... when changing it back to 18 upto 28 its cold... the air con turns off but only a tindy bit of heat... checked the simple stuff.. ie coolent...
    Going to get my laptop out and check VAGH-COM... however i think tjhe heater matrix has gone...
    Do any one know how to fit one on a A4 - B6??
    RicKT
    Dec 2006
    or does anyone know how to test it via VAG-COM??
    Dec 2006
    can you advise how to do this?????
    i have now charged my laptop and heading outside shortly!
    RicKT
    london/ UK
    Rick, log on the climate control and do an output test with the engine running and then with the engine switched off. Check for any blocked flaps...and clear any codes logged in the memory. If anything fails, make a note off the controller soft codding and then in adaptation channel 0(zero), do a save- This will reset the controller to the factory default values... Let us know how it goes...
    7 Post(s)
    As well as the output tests if you go into the measuring blocks you can observe the flap angles.
    I think they are measured in the range of 0 to 255, I don't know if this is degrees though.
    Anyway, when you press each control on the clima, you should see the flap angle changing on the screen.
    Also, the system (coolant) may need bleeding, I assume you know about this i.e. you need to partially slide the left hand coolant hose off the spigot of the matrix until you expose the bleed hole, then carefully top up coolant / let the air out from there... (this is on the Passat, should be the same on the A4)
    Dec 2006
    Cheers for this guys.... however... in regards to the climate control.... how do i view this in Vag-COM... i have looked and cant see the option??
    also... where to find the info regarding the flaps?
    cheers
    RickT
    7 Post(s)
    If you log into 08 Auto HVAC then selct the measuring blocks, scroll through the channel numbers using the up and down arrows until you find the flap angles.
    Depending upon what version you are running vagcom will either state what the measuring block is or not !
    What you are looking for are the measuring blocks that have a range between 0 and 255. To find the block that relates to the temp flap it will be a process of elimination.
    Dec 2006
    Thanks for that... i will have a look in the morning..
    RicKT
    Dec 2006
    cheers for that... im going to head out in a min to do this....
    However i noticed after a further look the collent seems to have dropped....
    Does the coolent run through the matrix on these??
    The car has been stood for a week in snow etc... however i topped the coolent up and heat seems to be coming back through........
    Im going to out and have a proper look now in the light!
    Cheers.. any other thoughts keep them coming!!
    RicKT
    Dec 2006
    looks like it is the themostat at fault..
    Just got to audi before they closed and got one...
    Will fit shortly and let you know the outcome!
    RicKT
  1. Avant heater matrix
    By Scotty Dave in forum 80 - 90
    Last Post: 27-10-2007, 08:00 PM
  2. Audi 80 tdi..heater matrix
    By domross in forum 80 - 90
    Last Post: 21-03-2007, 11:17 PM
  3. Heater Matrix leaked, Radweld recommended or not??
    By TDI in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 11-03-2007, 03:15 PM
  4. Heater matrix reinstall difficulties
    By narge in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 18-11-2006, 11:13 PM
  5. any one changed a haeter matrix?
    By chrispey in forum 80 - 90
    Last Post: 07-10-2006, 06:14 PM
