Thread: Vagcom/VCDS User Locations
Page 3 of 35 FirstFirst 1234513 ... LastLast
Results 21 to 30 of 344
  1. Re: Vagcom User Locations
    #21
    Jul 2007
    I have VAG-COM 409-1 (FULLY REGISTERED) & CABLE.
    EXPERIENCE: I've had it for around 6 months now, so am reasonably experienced, can do most things, but always learning.
    WILLING TO HELP OUT A FELLOW FORUM MEMBER FOR FREE, AS LONG AS I DON'T HAVE TO TRAVEL TOO FAR.
  2. Re: Vagcom User Locations
    #22
    Location: Belfast Interface: USB Cable & VAGCOM v4.09-1 [Full version] Experience: Still learning.
  3. Re: Vagcom User Locations
    #23
    Dec 2007
    Suffolk
    VAG-COM 704.1 HEX-USB-CAN
  4. Thumbs up Re: Vagcom User Locations
    #24
    LeFrog Guest
    Location: West Kingsdown, Nr Sevenoaks, KENT. (Brands Hatch)
    Interface: Ross Tech Micro-Can with Full VAG-COM licence and have just ordered a KKL lead via the group buy on this forum.
    Software: Latest release 704.1
    Experience: I own a B6 Passat estate on which I have fitted a factory tow bar/wiring loom and I have now successfully coded the trailer function along with the required changes to the ABS / Parking brake / Parking sensors.
    I have also read and cleared fault codes and changed various settings :-
    One press of the remote fob now opens all doors, the cental locking locks at 15MPH and then unlocks on removal of the ignition fob.
  5. Re: Vagcom User Locations
    #25
    London
    Location M11 corridor from East London to Cambridge
    Interface: Eshrules V Checker Pro
    Experience: None! Expecting delivery of it next week and will be learning myself. I don't have much experience of Audi faults either you may have to ask the forum additional questions but at least I can get the faults read out for you.
    No cost for the help, fuel or time except for mugs of coffee
  6. Re: Vagcom User Locations
    #26
    Bradford
    VAG-COM 409, vagtacho 1.1 (currently)
    been using vagcom for past couple of months reset fair few codes and airbag lights and basic diagnostics, done a few MAF logging. Still learning
  7. Re: Vagcom User Locations
    #27
    Jul 2007
    Near Maidstone, Kent
    Interface: HEX-CAN - Does Everything from 1998 onwards
    Ability: Fairly Advanced:- Long and Short Coding, Logging etc. Also see <please seek permission before advertising>
    Version: 704 and testing 711 beta!
  8. Re: Vagcom User Locations
    #28
    Mar 2007
    Location Nottingham
    Version of VAG-COM Fully registered 3.11
    Abilities you have basics, faulty code reading and a few other bits of adaptation,
  9. Re: Vagcom User Locations
    #29
    Version of VAG-COM : Fully registered 3.11
    Only just started using Vag-Com so bit of a novice. So far I've enabled cruise control, enabled auto locking/unlocking and "Beep" on locking/unlocking. Ceck for fault code.
    Car : VW Passat B5
  10. Re: Vagcom User Locations
    #30
    Mar 2008
    South East London
    Interface: KKL-OBD2/USB Cable & VAGCOM v4.09-1 [registered version]
    Experience: moderate use, use it alot on mine and my partners cars.
    Send me a PM.
  1. New VCDS ODB2 user- Lancashire
    By f2raf in forum VCDS - Help Requests
    Last Post: 08-09-2011, 10:47 AM
  2. nearest vagcom user (birmingham)
    By vwcamperman in forum VCDS - Help Requests
    Last Post: 23-11-2009, 01:05 AM
  3. Looking for VAGcom user in Northampton
    By 1.8tgav in forum VCDS - Help Requests
    Last Post: 17-11-2009, 04:42 PM
  4. Re: Vagcom User Locations
    By skippy41 in forum VCDS - Help Requests
    Last Post: 20-11-2008, 07:25 PM
  5. VagCom port locations
    By morticiaskeeper in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 29-07-2007, 02:10 PM
