Thread: Help!! 03 Transporter T4 2.5 tdi
  1. Help!! 03 Transporter T4 2.5 tdi
    Nov 2008
    Recently bought this van & now have a flashing yellow 'coil' lamp on dash. Have found out it indicates an error on engine management system. Can anyone recommend an appropriate code reader. Would also be good to know where the diagnostic socket is located. Thanks in advance.
  2. Re: Help!! 03 Transporter T4 2.5 tdi
    Jun 2008
    The Wee County
    Should be able to locate your diagnostic port location here.
    http://bitnet.ro/vw/obdlocation/
    Whats required has been talked to death on this site so a search through the threads will give you an idea of whats required.
    If you post your location someone local to you with Vag-com may be able to assist you
  1. VW T4 Transporter 2.5 tdi
    By bpx in forum The Commercial Range
    Last Post: 04-06-2010, 10:11 PM
  2. Question Which Transporter to Buy?
    By dottyscotty in forum Chat - Anything with wheels
    Last Post: 05-08-2008, 08:26 PM
  3. Please Help Transporter 1.9 tdi
    By timpackwood in forum The Commercial Range
    Last Post: 18-06-2008, 05:57 PM
  4. TRANSPORTER 2.5 TDI
    By DICKO in forum The Commercial Range
    Last Post: 01-11-2007, 02:02 PM
  5. VAG-COM TDi Transporter 2.5 (5-cyl) NO ECU
    By justinbaker in forum The Commercial Range
    Last Post: 01-07-2007, 06:20 PM
