Thread: audi a4 : FM stereo lost when rear window demister on
  1. audi a4 : FM stereo lost when rear window demister on
    mr_greenfelduk Guest
    Hi Guys
    Any ideas how I can solve this rather frustrating problem? Whenever I put on the rear window demister then FM stereo reception is greatly interefered with and radio becomes unbearable because of static.
    Is there a simple solution / problem for me to look for else am I adding this to a list of items I need to talk to me dealer about?
  2. Re: audi a4 : FM stereo lost when rear window demister on
    I have the same problem it's a pain in the ..... if you ever get a solution let me know please
  3. Re: audi a4 : FM stereo lost when rear window demister on
    Dec 2006
    Wiltshire
    2 possibilities;
    1) There is a shunt that prevent's electrical feedback that is fitted to the supply rail for the heated screen. It may have failed.
    2) The contact between the amplifier and the screen can be poor, which may introduce interference, that is highlighted when the screen is powered up.
    A6 (2007)TDi SE Avant
    Gone but not forgotten - A4 2.5TDi Avant, Imola Yellow S3 , Golf VR6 Highline
  4. Re: audi a4 : FM stereo lost when rear window demister on
    Thanks froggy I'll check it out
  5. Re: audi a4 : FM stereo lost when rear window demister on
    Nov 2008
    tis usually the rear screen at fault, the lines on the screen corrode and this can cause interference
  6. Re: audi a4 : FM stereo lost when rear window demister on
    108 Post(s)
    1816 Post(s)
    I have had this problem since my rear screen was taken out for paintwork, it completely destroys Radio 2 reception, not good! The windscreen blokes snapped off the tags and they soldered them back on, I don’t think they did a good job of it.
  7. Re: audi a4 : FM stereo lost when rear window demister on
    Mar 2009
    Quote Originally Posted by mr_greenfelduk View Post
    Hi Guys
    :zx11:
    I am searching for a solution to this same problem on my A6 (2006 model). Audi diagnosed fault as rear screen. I had it replaced by Autoglass (as dictated by my lease company) but it didn't fix the problem. Audi checked it again and reported that the new rear screen is not an approved Audi part and therefore can't continue with diagnostics.
    If anyone has suggestions for remedy I would be delighted.
    Mke
    Update July 2011: The solution (by Audi main dealer) was to replace the rear screen with a genuine part. Hey presto! Radio reception was restored and problem gone!
    Mike
    Last edited by JoshuaTreeMike; 26-07-2011 at 11:47 AM. Reason: Update with solution to the problem
  1. Audi A4 demister flap motor
    By plexman in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 10-11-2015, 08:10 AM
  2. Audi A3 54Reg - Replacement Stereo - loss of sound in rear speakers
    By Spikey in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 13-06-2009, 05:26 PM
  3. Avant rear screen demister not working
    By AndrewS1 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 11-10-2008, 03:19 PM
  4. Audi A6 rear window
    By chrissy077 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 27-03-2008, 10:01 AM
  5. Rear demister fault
    By Marc97 in forum 80 - 90
    Last Post: 22-01-2007, 04:11 AM
