Thread: Felicia 1999 1.3L - CV Joint
  1. Felicia 1999 1.3L - CV Joint
    May 2007
    Anyone had experience changing a Felicia cv joint? Easy enough or too hard (get the garage to do it) job? Expensive?
  2. Re: Felicia 1999 1.3L - CV Joint
    Nov 2008
    Beverley East Yorkshire
    Depending on your mechanical knowledge its quite a straight forward job,
    Remove the split pin from the driveshaft end and slacken the big nut by a turn then loosen the wheel nuts jack up and remove the wheel, remove bottom balljoint bolt and lever out the ball joint from the strut pull out the driveshaft from the wheel bearing (being carefull not to pull it out of the gearbox or you'll get an oily floor) remove cv boot get someone to hold the driveshaft and knock of the joint with a soft faced hammer. rebuild is just reversed.
    Hoppe that helps.
  3. Re: Felicia 1999 1.3L - CV Joint
    May 2007
    Should be able to manage that. Thanks for your help "Size12".
  1. Felicia 1997 1.3 LXi (MPI) - Tappet Noise
    By BugBit in forum Other Models
    Last Post: 21-10-2008, 10:38 PM
  2. Felicia 1.6
    By rooster in forum Other Models
    Last Post: 14-07-2008, 06:58 PM
  3. felicia 1998 1.9 tdi cam belt
    By fabeiac in forum Other Models
    Last Post: 08-06-2008, 10:58 AM
  4. inner cv joint
    By cw215972 in forum Golf MK3 - 1993 - 1999
    Last Post: 08-05-2008, 07:53 PM
  5. Felicia 1.9nonturbo Diesel
    By AGS in forum Other Models
    Last Post: 09-03-2008, 11:15 AM
