Thread: Touran brake light problem
Results 11 to 20 of 33
  1. Re: Touran brake light problem
    Nov 2008
    Quote Originally Posted by kenney View Post
    Iam guessing now but i think the brake light switch is receiving a signal from the ECU,due to a faulty clutch pedal switch.There are two types of switches the earlier models had the switch above the clutch pedal,and the later models it is attached to the clutch master cylinder.You need to pull the contact off what ever one it is.
    Faulty clutch pedal switch pulled the contact off it and brake lights out and fault away off the dash . It is the one with the switch at the cylinder now do any of you know now to get at it to replace it do you have to take the pedal out and go in that way or what
  2. Re: Touran brake light problem
    Hi You have to remove the battery and the battery tray,a bit awkward to get at but not the worst of jobs
  3. Re: Touran brake light problem
    Nov 2008
    If i remove all that will that let me reach over to get at it
  4. Re: Touran brake light problem
    Sorry matey it just struck me,you see i work on LHD vehicles,so what i said,might not be the same for the RHD.Bugger it why cant you lot drive on the RIGHT side of the road.What side is the battery on?
  5. Re: Touran brake light problem
    1840 Post(s)
    I didn't like to say anything...
  6. Re: Touran brake light problem
    Nov 2008
    Not going to be easy to remove then now i wish it was lhd is ther any down side in leaving it like this for a wile and just driveing away at her
  7. Re: Touran brake light problem
    #17
    Your cruise control will not work
  8. Re: Touran brake light problem
    #18
    Nov 2008
    I can live with that i live in ireland and never need it the car is never on a long enfough road
  9. Re: Touran brake light problem
    #19
    Aug 2019
    Liverpool
    Hi I have the same problem want to check via the clutch pedal switch its an 04 TDI is the switch at the pedal or the master cylinder thanks in advance
  10. Re: Touran brake light problem
    #20
    1840 Post(s)
    This thread is eleven years old, you will get a better response by starting your own new thread. It is on the pedal box above the pedal, part number 1K2 945 511 RDW and £14.83 from a VW dealer.
  1. touran brake light help
    By wullie in forum Touran - Sharan - Caravelle
    Last Post: 27-09-2011, 02:45 PM
  2. Touran - brake light
    By sood in forum Touran - Sharan - Caravelle
    Last Post: 05-01-2009, 06:46 PM
  3. Brake light problem
    By FLHRCI in forum Passat - B5 Forum - 1997 -2005
    Last Post: 18-09-2008, 08:50 PM
  4. Brake light problem on Touran
    By andrewwhite21 in forum Touran - Sharan - Caravelle
    Last Post: 16-04-2007, 02:58 PM
  5. Brake Light Problem.help Please!
    By Wiganbargee in forum Archive posts
    Last Post: 03-04-2007, 09:29 PM
