Thread: Passat tdi timing belt question
  1. Passat tdi timing belt question
    Nov 2006
    I recently had the timing belt on my 2003 130pd tdi engine replaced.
    During a service at the weekend I checked the belt and notice that the cam shaft toothed pulley is adjusted so that the three locking bolts are at the end of their adjustment slots, whereas they were originally in the middle. I had thought that the engine was a bit harsher that before, and wonder if the cam timing could be out?.
    It was done at an independant VW specialist who are well known and respected.
    Does anyone know if the timing could still be correct with the slots this far out?
    Many thanks.
    Feb 2007
    Newcastle upon tyne
    the three bolts are meant to be loosened and the pulley turned anit-clockwise when the belt is replaced, then the belt tension is set, then the bolts are retightened. they should be around the middle though so there is a chance it is slightly out
  1. passat 1.9 tdi sport timing belt ??
    By tennentsfan in forum Passat - B5 Forum - 1997 -2005
    Last Post: 18-05-2008, 01:01 PM
  2. Cam belt timing belt tip , general
    By Conradvw in forum Archive posts
    Last Post: 11-01-2007, 04:29 PM
  3. timing belt/ cam belt change
    By jonoallen in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 26-11-2006, 01:24 PM
  4. Passat Timing Belt Tools
    By ignoranceisntbliss in forum Passat - Archive Topics
    Last Post: 09-06-2006, 03:58 PM
  5. Passat TDI PD timing belt intervals
    By 6Speeder in forum Passat - Archive Topics
    Last Post: 11-02-2006, 12:48 AM
