Thread: 2.0 tfsi engine knock
Results 1 to 10 of 11
  1. 2.0 tfsi engine knock
    Nov 2008
    Just bought an 05 a3 2.0 tfsi quattro 33000 miles.
    Engine sounds smooth when starting from cold but when @ temperature I can here slight tapping at idle only, almost like a deisel. Not sure if this is a valve issue. Driving & at speed engine is sweet as a nut
    I Have heard this is a symptom of these engines and is normal however I will get this checked out at the garage. Does anyone else know of this problem?
  2. Re: 2.0 tfsi engine knock
    If your using poor fuel Try better fuel
    Mike
    info@ motechperformance.co.uk
  3. Re: 2.0 tfsi engine knock
    Nov 2008
    Quote Originally Posted by motechmike View Post
    Mike
    Thanks Mike
    I will try super unleaded next fill up
    Neil
  4. Re: 2.0 tfsi engine knock
    Run the tank ur on now dry then out £5.00 of super in run that dry then a ful tank of super.. On that engine u should run super all the time really
    keep us up todate
    thanks Mike
  5. Talking Re: 2.0 tfsi engine knock
    Feb 2006
    keep us up todate
    thanks Mike
    Just a quick one, I have this noise to and was told by Audi that the sound is normal as its the injectors that make the noise..... how true is this or are they full of it as usual ???? So running it on super should do away with the knocking/tappety sound??
  6. Re: 2.0 tfsi engine knock
    Bristol
    i have just come back from audi as my car was knocking in reverse but then stopped when i got there ! Any way seems to have gone now, but i also asked about the engine because it sounded loud and they said that the 2.0T fsi engines are loud... He brought another one out and it sounded the same so im happy!
  7. Re: 2.0 tfsi engine knock
    Feb 2006
    But is it worth it putting super in it??
  8. Re: 2.0 tfsi engine knock
    Milton Keynes
    Super unleaded (98 ron) will give more power at Wide open throttle as the engine can advance the spark more until knock occurs. so running super unleaded will improve your acceleration times.
    During normal cruising and driving in traffic the effect of super will not be noticed as higher knock rating is less important. Super may give very marginal improvements in fuel consumption but you're not likely to notice it.
    I never use super in my 2.0T , its just fine on regular unleaded (95 ron).
    Run it on regular 95ron from a branded outlet (shell BP etc) and it will be fine. Steer clear of the supermarket stuff.
    2007 A3 2.0T FSI Quattro - Sold
  9. Re: 2.0 tfsi engine knock
    Feb 2006
    Quote Originally Posted by engineermk View Post
    Cheers for your reply, but surely it don't matter where you get your 95 ron from as it will come from the same refinery regardless if its BP or Tescos.
  10. Re: 2.0 tfsi engine knock
    Milton Keynes
    Quote Originally Posted by smudger View Post
    True, its all from the same refinery but the additives put in at the time the fuel is dropped in to the filling station tanks differ between brands. these additvies help to keep the injectors clean and reduce carbon buildup on the valves etc.
    My company tests these additives, i know they make a differnce to the long term condition of the engine. I may use 95RON but i always use branded fuel.
  1. knock knock knock dam noise
    By mbu10 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 03-06-2010, 11:19 PM
  2. Realistic MPG for 1.8 TFSI and 2.0 TFSI?
    By jsgreen89 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 10-07-2009, 12:13 PM
  3. subtle knock from engine????
    By finngalway1 in forum Golf MK4 - 1999 - 2004
    Last Post: 29-11-2008, 01:44 PM
  4. 2.0 TFSI engine chip
    By sauber in forum Audi A5 - B8 Forum - 2007 - 2016
    Last Post: 22-10-2008, 07:27 PM
  5. 1.4 Tfsi
    By cuprasport in forum Golf MK5 - 2004 - 2009
    Last Post: 22-06-2008, 09:30 PM
