Thread: Flat battery
  1. Flat battery
    Sep 2007
    Ive got a TDI 130 and its got a flat battery is it safe to run jump leads off another car to start it so i can get it down to the garage to get a new one or is it possible to push it and jump start it and how do i get the raadio code as i dont have it without getting ripped off by the main *******
  2. Re: Flat battery
    Bath, Somerset
    This thread https://www.vwaudiforum.co.uk/forum/s...ad.php?t=51896 discussed the result of jump starting with leads. If I were you I would get a new battery (in a different car) and then fit it to your car.
    I don't think you can jump start diesels easily either due to the glow plugs and electric fuel pump...
    Radio code is a dealer only thing but there are members on here who can get the code if you E-mail them your serial number on the radio...
  3. Re: Flat battery
    Aug 2008
    Wigan
    9 Post(s)
    Top tip from tech staff at a lead acid battery manufacturer (passed on to me when I started working there). Your battery supplier will probably tell you the battery is fully charged. It won't be, because it's been standing around since it was made. If you want to give it maximum life and starting power, put it on charge for at least 4 hours before you use it. Unless it's a sealed maintenance free battery, it will bubble while it's charging. This is hydrogen and oxygen coming off as the water in the acid breaks down - it's an explosive mixture so allow ventilation and avoid naked flames and sparks. If it doesn't bubble, carry on charging until it does and then 2 hours more. You shouldn't need to add distilled water for such a short charge. PS have you tried charging your 'dead' battery?
  1. Please Help battery keeps going flat
    By lolly in forum Golf MK3 - 1993 - 1999
    Last Post: 11-08-2008, 02:32 PM
  2. why has my battery gone flat???
    Last Post: 22-04-2008, 10:19 PM
  3. Flat Battery
    By Donjon in forum Octavia
    Last Post: 29-07-2007, 12:57 AM
  4. Battery goes flat!!!
    By southwest in forum Passat - Archive Topics
    Last Post: 06-03-2007, 01:06 AM
  5. Battery Flat In Fob??
    By bizzle in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 28-02-2007, 11:23 AM
