Thread: Water leak when parked uphill only!
  1. Water leak when parked uphill only!
    Dec 2006
    My pollen filter was sorted out under recall and I removed the grommets in the plenum chamber to cure a previous water leak. Now I have another leak problem, six months after dealing with the grommets. My drive is on a slope and, if the car is parked facing uphill, then the carpets get wet. I have now trained myself to park downhill and the carpets dried out - no problems even in torrential rain and no problems if parked on the flat. Took the car on holiday and left it for three days parked uphill with the result that the passenger side carpets were squelching with water. It's eventually dried out again now that the car has only been parked downhill for a few months. I can live with this but anyone got any suggestions?
  2. Re: Water leak when parked uphill only!
    Have a look at the rubber grommet on the wire which opens the bonnet.
  3. Re: Water leak when parked uphill only!
    Dec 2006
    Quote Originally Posted by kenney View Post
    Thanks - something new to try!
  4. Re: Water leak when parked uphill only!
    Dec 2006
    Quote Originally Posted by Rog View Post
    Just had a look but it's on the driver's side so would appear to be unlikely
  5. Re: Water leak when parked uphill only!
    Tyldesley, Manchester, UK
    Not much help. These cars are **** for leaking. I can park mine under cover at work more often than not. I take full advantage of this.
    Mrs QV's MX5 has never leaked like my Passat
    One German, Two Italian.
  6. Re: Water leak when parked uphill only!
    Dec 2011
    gwynedd
    It still has to be the pollen filter housing?
    Was it repaired using the D-shaped non setting rope applied to the underside of a cleaned off housing and then replaced.......or was the seal used the closed cell foam as originally fitted? Have you resealed the ECU.........My 2002 Estate was done under Warranty in 2004 with new carpets and I know that they did pollen filter housing , ECU and Bonnet pull grommet. It has remained dry since. I never park under trees and clear drain holes once a year.
  1. Please Help Water Leak
    By saj26 in forum Audi A3 - Archive Topics
    Last Post: 27-10-2008, 06:52 PM
  2. B5.5 Water Leak
    By Mike'A in forum Passat - B5 Forum - 1997 -2005
    Last Post: 16-09-2008, 10:35 PM
  3. a4 b5 water leak help
    By chrissgoduk in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 26-01-2008, 10:37 PM
  4. water leak
    By mark740_5 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 17-01-2008, 11:37 PM
  5. water leak !
    By hitachi in forum Passat - B5 Forum - 1997 -2005
    Last Post: 12-07-2007, 08:57 PM
