Thread: Golf Gt Tdi 110 "limp Mode" Problem
Results 1 to 9 of 9
  1. Golf Gt Tdi 110 "limp Mode" Problem
    I would be grateful if you could all help me!
    I have a 2001 VW Golf GT TDI 110HP. For some reason, when taking the car up to 65-70MPH, it shuts the power off and the turbo feels like it isnt coming in.
    If I turn the engine off and back on again, it is perfect again until hitting that speed.
    There are no lights present on the dash.
    Does anyone have any information? I would appreciate it.
    Kind Regards,
    James
  2. Re: Golf Gt Tdi 110 "limp Mode" Problem
    SHEFFIELD
    Would need to be plugged in to be correct but normal reasons are either maf sensor or boost pressure regulator,there both very common for the symptoms
    I dont work here for the pay,or the enjoyment,so why do i work here
  3. Re: Golf Gt Tdi 110 "limp Mode" Problem
    Aug 2008
    Wigan
    9 Post(s)
    Sounds like a MAF (air flow meter) problem. I've come across two similar problems; one on a mk4 GTTdi and the other on my mk3 tdi estate. Both cars felt normal to drive at part throttle but at high to full throttle it was as though someone had thrown out the anchor and chain - absolutely no go at all. On the motorway part throttle acceleration was OK and could get up to 60-70 depending on the gradient. On a hill the speed just fell away; pressing the accelerator did nothing. They're easy to change and seem to be readily available on e-bay if you're prepared to take a chance on someone telling the truth about their "geniune VW" part. If not, get one from VW at about £75.00 but make sure you match the part number whichever you choose.
  4. Re: Golf Gt Tdi 110 "limp Mode" Problem
    1837 Post(s)
    I would expect a fault code read to show overboost code “17965 (P1557) Charge pressure control limit exceeded”, so probably sticking turbo vanes.
  5. Re: Golf Gt Tdi 110 "limp Mode" Problem
    Sounds like that to me too.....
    info@ motechperformance.co.uk
  6. Re: Golf Gt Tdi 110 "limp Mode" Problem
    north east
    just wondering if the 2001 gt tdi is pd 115 bhp not 110 bhp
  7. Re: Golf Gt Tdi 110 "limp Mode" Problem
    1837 Post(s)
  8. Re: Golf Gt Tdi 110 "limp Mode" Problem
    Isnt It Funny I Have Exactly The Same Problem At The Moment I Am Investing In A Boost Control Valve Its Attached To The Bulkhead It Has 3 Pipes On It And 1 Wire Thats Most Likly To Be The Problem Im 99% Mate Mine Is Orderd To Pick Up On Tues Only £34 From Vw!!!!!
  9. Re: Golf Gt Tdi 110 "limp Mode" Problem
    carbed vanes could be the problem, but seen as the vanes adjust using readings from the MAF (and others) i doubt it...
    my bet is the MAF... and is MUCH cheaper than geting the turbo re-conned.
    PS... PD115
  1. Replies: 28
    Last Post: 02-11-2009, 11:08 PM
  2. "limp home" ?
    By Lettuce in forum 80 - 90
    Last Post: 24-09-2008, 09:16 PM
  3. Radio "2 SAFE" mode
    By brokendub in forum Passat - B5 Forum - 1997 -2005
    Last Post: 07-05-2008, 01:33 AM
  4. "Charge Pressure Deviation" - Limp mode
    By devonutopia in forum Archive posts
    Last Post: 01-04-2007, 06:11 PM
