Thread: Rust on wheel Nut casing
  1. Rust on wheel Nut casing
    Hi, I have a 07 Jetta SE and have noticed a rust build up the wheel Nut casing (not sure if that is exactly what it is called), which can be seen clearly when you look through the Atlanta Alloys. Has anyone else had this occur and did you perhaps find a solution with either VW or else where. I have been advised it is not a problem, however it does not look all that great close up
    Thanks.
  2. Re: Rust on wheel Nut casing
    Chester-le-Street, United Kingdom
    every car is the same. some people paint them,as they do the calipers, but having painted them, you need to keep on top of them,otherwise they look worse than the rust!!!
    first time i was up a ladder i was down a well
    4th cog,--two to go
  3. Re: Rust on wheel Nut casing
    Thanks Stewy L.
  1. Light casing condensation
    By lucas88 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 29-02-2008, 10:57 PM
  2. Replacement Key remote casing
    By claranet in forum Passat - B5 Forum - 1997 -2005
    Last Post: 30-10-2007, 11:19 PM
  3. Removing Wing Mirror Casing - Help Needed !!
    By MIKAY in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 01-10-2007, 12:34 AM
  4. A3 Removing wing mirror casing
    By Golddog in forum Audi A3 - Archive Topics
    Last Post: 28-08-2007, 03:01 PM
  5. Alternator casing
    By JBOB in forum Scirocco - Corrado
    Last Post: 13-06-2005, 05:50 PM
