Thread: egr blanking plates vs vag com reduce on afn engine
  1. egr blanking plates vs vag com reduce on afn engine
    Stafford, Midlands
    toyed with the idea of getting rid of egr and fitting blanking plates, but am unsure what the vaccum pipe blanking off would do. as its not a larger bore egr like on the golfs that ive seen on internet, the egr on mine is tiny. after undoing it to check for blockages etc, there seems to be hardly any crap in the manifold and certainly no restriction to exhaust gas. have just registered my vag com and am waiting for the code to register it back off ross tech. adjusting the egr when i get it to see what affect it has on all the air sensors etc.
    anything i should maybe not do?
    allard say they do a pipe for the 110 but im pretty sure it isnt for the afn engine
    Subaru broken, sold, Silver Seat Leon Cupra 180 '02' no cupra badge?
  2. Re: egr blanking plates vs vag com reduce on afn engine
    1840 Post(s)
    Dial it out?
  3. Re: egr blanking plates vs vag com reduce on afn engine
    Stafford, Midlands
    it does seem like a pretty weedy valve on the afn anyway, so i guess i'll just do it when my vag com code comes. will post results on here anyway, anything i see that changes on vag scope etc
  4. Re: egr blanking plates vs vag com reduce on afn engine
    Stafford, Midlands
    have done it via vag com and it works a treat now, better than blanking off i reckon and keeps it looking stock
    didnt read emissions before and after but i will check soon.
  5. Re: egr blanking plates vs vag com reduce on afn engine
    Apr 2007
    Lancashire
    The simplest way is to remove the rubber vac tube, and push a tight fitting ballbearing into it, then reconnect to the EGR.
    Vagcom does not seem to reduce the EGR function very much over standard.
    All things considered, I would keep the EGR functioning at the reduced level, unless you are trying to squeeze every drop of power from the engine.
  6. Re: egr blanking plates vs vag com reduce on afn engine
    Stafford, Midlands
    it is only set to the figure given on here, cured my engine stutter though so im quite happy about that. would never bodge my engine with a ball bearing or anything?!
  7. Re: egr blanking plates vs vag com reduce on afn engine
    Quote Originally Posted by ini View Post
    I tried blocking the vacuum tube and plugging the breather holes in the EGR to stop the oil sputtering, when I drove the car it had no power above 3000 RPM, seemed to go into limp mode. I did not expect this, could it have been remapped with a leaky EGR and blocking the breather holes take it above max boost pressure? I have had it turned down in Vagcom for months but the oil sputtering is a bind and a new EGR seems a lot of money to cure it.
    I checked for error codes afterwards but nothing showed.
  1. VW plates, silver/black plates, German style plates...
    By SpecialPlatesCom in forum Chat - Completely Off Topic
    Last Post: 08-09-2008, 10:28 PM
  2. Blanking plate for glove box CD multi-changer?
    By toff in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 12-06-2008, 08:31 AM
  3. Reduce emissions
    By cbrpaul in forum VCDS - General Questions
    Last Post: 05-05-2008, 02:47 PM
  4. How to reduce the sensetivity of the [factory std] alarm
    By Jasonz in forum Golf MK4 - 1999 - 2004
    Last Post: 24-04-2008, 01:38 PM
  5. Tdi engine plates and water leak
    By M.D in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 22-04-2008, 09:14 AM
