Has anyone had problems with the ignition switch causing an intermittent starting fault, every now and then, I turn the key and it sounds like the solenoid goes in but the starter doesnt turn, try it srtaight after and it fires up no problem, the car is a TDI 130 AWX with 99k on it, Ive checked all the usuall things, battery, battery connections, body earth, engine earth, starter motor connections and all look good. Ive seen a few threads that mention the ignition switch, hence the question.
