Thread: Golf mk2 16v gti misfire shudder misfire
Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 36
  1. Re: Golf mk2 16v gti misfire shudder misfire
    #21
    I am thinking to put a ABF bottom end, what problems can this cause then? The engine block is taller will this effect closing the bonnet. The garage did mention that the block will be taller, but closing the bonnet should be ok.
  2. Re: Golf mk2 16v gti misfire shudder misfire
    #22
    1837 Post(s)
    The block is 16-mm taller so this causes problems with the front pipe angle and the bonnet can hit the throttle linkage. I will not use the ABF (except in throttle body applications like on my own Golf 2 which is a 2.2 in an ABF block) only the 9A.
  3. Re: Golf mk2 16v gti misfire shudder misfire
    #23
    Thanks Crasher, i have spoke to the garage and have decided to spend the extra money and get the 9a block as you recommended (rebuilt). I am also getting a gas flowed head but this is a 16v abf one.
    With these changes, what else needs to be done? Also what sort or BHP figures are we looking at? Will the KR cams be ok?
    Will the driveability be better, and will this affect the reliability. Any known issues after this engine change? Is it something you recommend.
  4. Re: Golf mk2 16v gti misfire shudder misfire
    #24
    Sep 2008
    Birmingham
    Quote Originally Posted by paramananthamd View Post
    I'd have thought you'd be looking at around 170/180bhp with the gas flowed head and cams but I'm sure Crasher will give a more accurate figure.
    A tubular exhaust manifold should help with the mid range torque aswell.
  5. Re: Golf mk2 16v gti misfire shudder misfire
    #25
    Thanks for that info, I will wait for Crashers input and see what he comes up with.
    Any ideas of any insurance companies that will insure this car that has the bottom block changed to a 2 litre. I phoned up mine to tell them of the change and they said they will not insure it has the engine is not a standard 1.8. Cheers
  6. Re: Golf mk2 16v gti misfire shudder misfire
    #26
    Sep 2008
    Birmingham
    Try Chris Knott they've given me a very cheap quote on mine with all the Mods declared. If they're no good pm me and I'll get you the number for Brentacre, another modded VW specialists that are well cheap.
  7. Re: Golf mk2 16v gti misfire shudder misfire
    #27
    Also after this engine swap will all the wiring be ok, and all the senors ie. temp sensor etc...
  8. Re: Golf mk2 16v gti misfire shudder misfire
    #28
    Also, will the original ECU be ok?
  9. Re: Golf mk2 16v gti misfire shudder misfire
    #29
    1837 Post(s)
    A rebuilt 9A is a mugs game, don’t do it. Find a worn out 9A and hand it back to VW for an exchange unit, they cost £1050, a set of 9A pistons costs £500 and if they use KS pistons it will never stop burning oil. I would suggest you stick with a KR head.
    The KR ECU is fine but the fuelling will need increasing by roughly 20%
  10. Re: Golf mk2 16v gti misfire shudder misfire
    #30
    Sep 2008
    Birmingham
    Can that be done with an adjustable or rising rate fpr?
    Or is it mapping accordingly?
  1. misfire golf 1.8t
    By wrensupernova in forum VCDS - General Questions
    Last Post: 22-05-2008, 09:04 PM
  2. Golf Mk4 2.0 Gti judder / misfire? - help!
    By ian davies in forum Golf MK4 - 1999 - 2004
    Last Post: 19-04-2008, 05:45 PM
  3. misfire@ 1200rpm golf mk4 tdi
    By rimk4gttdi in forum Golf MK4 - 1999 - 2004
    Last Post: 18-04-2008, 07:06 PM
  4. golf 4 misfire
    By kalahari in forum Golf MK4 - 1999 - 2004
    Last Post: 25-02-2008, 01:35 PM
  5. 1997 Golf GTI 2.0 16v misfire
    By Tommyl1968 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 23-07-2007, 02:33 AM
