Thread: Odd Electrical issue - 2.0E ABK 1992
  1. Odd Electrical issue - 2.0E ABK 1992
    Reading
    Hi All,
    Over the weekend i rewired the stereo, as it was on a perm live so would not switch off with ignition, the previous owner had done a bit of a hatchet job lots of chop blocks grrrr, but I was able to find a switched live via my trusty multimeter. with the car stationary all is good turns on and off as it should, but when driving the stereo cuts out when i go over 40mph, then will come back on when i am at a slower speed, its really quite odd.
    I've gone back thru the wiring and there are no loose wires i can find, so i'm at a loss. Anyone had similar problems or has an idea as to what is wrong?
  2. Re: Odd Electrical issue - 2.0E ABK 1992
    Reading
    Still doing the cut off, but it happens at 45mph in any gear! will remain off until under that speed and a wait of about 1 minute!
    I've wired the stereo back to how it was, just interested in what is causing it.
    The wire in question is white with a blue stripe.
  3. Re: Odd Electrical issue - 2.0E ABK 1992
    Gwent
    wouldn't be surprised if its the speed sensor wire? I think the diesel judderers snip the white/blue vss wire to help with their problem..
    2001 Passat Sport tdi 130hp
    1990 Audi coupe 20v x 2
  1. 05 2.0tdi Idle issue & '97 1.8 engine issue
    By dbbear in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 18-08-2009, 02:11 PM
  2. Golf 1992 CL 1.8 petrol
    By campbellditty in forum Golf MK3 - 1993 - 1999
    Last Post: 10-01-2009, 11:56 AM
  3. Please Help air con problem with Passat 1992
    By bluecow in forum New Member Introductions
    Last Post: 07-09-2008, 07:50 PM
  4. 1992 jetta, No Spark??
    By saxonrod in forum Jetta MK2 - 1984 - 1992
    Last Post: 25-07-2008, 11:45 AM
  5. Which head unit for a 1992 Mk2 GTI 8v?
    By RichieL in forum Golf MK2 - 1984 - 1992
    Last Post: 21-05-2007, 09:20 PM
