Thread: MK4 TDI Squeal when accelerating
  1. MK4 TDI Squeal when accelerating
    Aug 2008
    Hello,
    Just recently had new cam and timing belt fitted, however, i now get a squealing noise when i accelerate and hit high revs, also when driving up steep hills, still get this squealing?
    Any advice would be much appreciated.
    Ross
  2. Re: MK4 TDI Squeal when accelerating
    Apr 2007
    N.Ireland
    When you got the new timing belt fitted, did you also get a new tensioner fitted?
    Golf GTD 2.0 DSG (ACC | Winter Pack | 18" Vancouvers | RCD510 | Parking Sensors, Rear Camera & Park Assist | Cruise Control | Flat Tyre Indicator | Luxury Pack | Rear Airbags)
  3. Re: MK4 TDI Squeal when accelerating
    SHEFFIELD
    also could be powersteering belt that needs replacing or the tensioner for that,this would also make a squealing noise when been worked or it maybe under tension and slipping when been worked harder ie up hill steering etc
    I dont work here for the pay,or the enjoyment,so why do i work here
  4. Re: MK4 TDI Squeal when accelerating
    Aug 2008
    Yep new tensioner fitted, all rollers and bearings replaced too.
  5. Re: MK4 TDI Squeal when accelerating
    Aug 2008
    I will give the power steering a check, now you mention, the power steering does seem not as smooth as it has been.
    Cheers for your help!!
  6. Re: MK4 TDI Squeal when accelerating
    SHEFFIELD
    I would definately say its power steering weather its belt not tensioning right or belt slipping cos worn or,what about fluid is there ps fluid in there ? is it correct stuff? its been mentioned on threads before where they move reservoir to change belts then either top it up too much for the bit they have lost,or put wrong fluid in etc etc etc
  1. Air Con Belt Squeal
    By mrcheeezy in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 19-06-2008, 10:28 PM
  2. Question squeal / squeak
    By PETER G in forum Passat - B5 Forum - 1997 -2005
    Last Post: 11-06-2008, 10:56 PM
  3. Brake squeal after 2000mls
    By jlo in forum Chat - Anything with wheels
    Last Post: 06-05-2008, 06:45 PM
  4. a4 brake squeal
    By rjohnson in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 24-03-2008, 01:34 AM
  5. Nearside squeal
    By Adpro2 in forum Audi A3 - Archive Topics
    Last Post: 23-12-2007, 01:44 PM
