Thread: A6 Outer CV Joint
  1. A6 Outer CV Joint
    Jul 2008
    Have an A6 with clicking from front wheel when pulling away and turning. Presume it is Outer CV joint. Is this is easy repacement to do or do I need specialist tools?
  2. Re: A6 Outer CV Joint
    There are a few suspension links to drop off as you have the ease the hub assemble out of the way to remove the drive shaft after unbolting it from the inner CVJ. Then all the work is done in the garage and vice. This also give you the chance to clean and re-pack the inner CV joint and change the boot is looking a bit old. With the right tool 3207 or a machined down M14 bolt you can just remove the outer CVJ without removing the Drive Shaft. What model, engine code and gearbox code do you have. It is on a label in the service book and in the spare wheel bay. Regards Peter
  3. Re: A6 Outer CV Joint
    Jul 2008
    Thanks Peter.. That was quick... Am in Saudi until Saturday, so can't respond with those details at the moment . Curiosity..what is a 3207 tool?
  4. Re: A6 Outer CV Joint
    Mar 2008
    High Wycombe
    Quote Originally Posted by birdseed View Post
    https://erwin.volkswagen.de/workshop...ezial/3207.htm
    From the picture, I can't see how it's used, but I've never done a CV joint on this car (I suspect that's "Yet")
    2002 Passat 1.9tdi
    2004 A3 2.0 FSI
  5. Re: A6 Outer CV Joint
    This device screws into the the thread hole in the outer CV joint that the retaining bolt came out of, and the turned down end engages in a hole in the drive shaft and on turning further 'pops' the outer CV joint off the circlip which is on the end of the drive shaft thus enabling removal of the CVJ without removing the whole drive shaft. Look at the drawing I sent you and it will all come together. Regards Peter
  1. outer cv joint
    By asadomar76 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 04-04-2008, 09:42 AM
  2. GOLF RALLYE BBS Outer RIMS???
    By sabikeuk in forum Golf MK2 - 1984 - 1992
    Last Post: 11-03-2008, 02:33 PM
  3. Outer CV joints
    By jimbo73 in forum Archive posts
    Last Post: 26-11-2006, 04:58 PM
  4. Sharan CV outer
    By Scarrowman in forum Touran - Sharan - Caravelle
    Last Post: 08-07-2006, 10:23 PM
