Thread: A4 1.9TDI Intermittent power fault
  1. A4 1.9TDI Intermittent power fault
    Dec 2006
    Hi all....
    I have been getting an intermittent fault which I can only describe to be as if the car were petrol and had a dodgy spark plug. Now and then I will be accelerating and then all of a sudden it is like the car has a drop in power (just like a car running on 3 cylinders when it should be 4) it will then run like that until I switch off, when I restart it is fine again. when it happens now I switch off as I am coasting and switch on again and it is back to full power.... any ideas please...
    Thanks in advance.
    Dec 2006
    I have juat read the Thread "SMOKEY A4 19 TDI " posted by brendanMC, it looks like its the same problems that I am having... so I will follow up some of the suggestions there, unless of course anyone has any other ideas....
  3. Re: A4 1.9TDI Intermittent power fault
    west midlands.
    Quote Originally Posted by Dave.jj View Post
    Hi all....
    Thanks in advance.
    HI, SOUNDS LIKE WATER TEMP SWITCH THAT COMUNICATES WITH THE ECU ON FUEL MIXTURE, ON THE TOP THE HEAD ON THE RIGHT SIDE AS YOUR STANDING IN FRONT OF THE ENGINE, TOWARDS THE BACK THEIRS A PLASTIC COWLING WITH THE WATER PIPE COMING OFF IT, INSIDE THE COWLING IS THE SENSOR WITH A WIRE COMING OFF IT THERE ABOUT £20 FROM AUDI. LET ME KNOW HOW YOU GET ON.
  1. Please help!Intermittent Immobiliser fault
    By nezz in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 01-11-2007, 10:20 AM
  2. A6 TDI 130 PD Intermittent power loss
    By really wants an RS6 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 15-02-2007, 09:33 AM
  3. A4 TDI 130 intermittent power loss
    By chris.b in forum Audi A4 - Archive Topics
    Last Post: 30-11-2006, 10:15 PM
  4. A3 Sportback intermittent interior light fault
    By mikelds in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 11-10-2006, 09:04 PM
  5. A4 2.5tdi intermittent, then solid, power loss
    By rob7706 in forum Archive posts
    Last Post: 05-10-2006, 08:00 PM
