Thread: Possible Air leak
  1. Possible Air leak
    Sep 2008
    Cheshire UK
    Hi All hope you have all had a good week and are enjoying the weekend weather thus far
    Just a quicky here thought i would see if i can get any feedback.
    Basically when the turbo kicks in on my GT TDI 150, you can hear what to me sounds like air escaping from the lower part of the engine bay, this only happens for a short period of time untill the turbo fades out again, im thinking possibly a crack or something in the air intake / inductor below the engine bay, as im new to owniing a VW i thought i would try my luck here first incase once of you guys has come across this before.
    Many thanks in advance
    Robbie
  2. Re: Possible Air leak
    Dec 2007
    Suffolk
    Check all the pipes are on properly and not split or it could be a hole the intercooler. Does it still pull well?
  3. Re: Possible Air leak
    Sep 2008
    Cheshire UK
    yeah still pulls, slight loss of power though i feel, the mrs dosent seem to think so but then again what does she know :P
    The sound though is pretty noticable, and definatly air imo, luckily still have a little warranty so should be sorted
    If not how much would you gauge a repair job?
    Robbie
  4. Re: Possible Air leak
    Sep 2008
    Cheshire UK
    Actually sond is coming from too far back, quite close to the turbo, theres an orange pipe coming off it, I think it is coming from there if that helps
    Robbie
  5. Re: Possible Air leak
    Mar 2008
    DURHAM
    i had an high pitched whistle just as i come onto boost when i removed the orange pipe from the turbo i found that the locating lug on the metal part of the pipe had worn through on the clip causing the boost leak.hope this is of some help. tony
  1. Radiator leak stopped with stop leak
    By BLASTER in forum Passat - B5 Forum - 1997 -2005
    Last Post: 13-08-2008, 08:16 PM
  2. Serious Leak!
    By pno in forum Golf MK3 - 1993 - 1999
    Last Post: 14-07-2008, 04:53 PM
  3. oil leak, help please
    By vwj4cko in forum Golf MK3 - 1993 - 1999
    Last Post: 13-03-2008, 09:57 AM
  4. Oil Leak on B5.5 130 PD TDI
    By Mike'A in forum Passat - B5 Forum - 1997 -2005
    Last Post: 11-03-2008, 06:53 PM
  5. A4 TDi Oil Leak
    By Woz in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 30-10-2007, 02:46 PM
