Thread: 2005 allroad gps antenna
  1. 2005 allroad gps antenna
    Aug 2008
    just had my 2005 allroad serviced 60 k service, today.
    the dealer tells me that the antenna was wet and so the reason for my gps not knowing my position on the road. So my questions are:
    How do i remove the head cloth to check out the antenna?
    Has anyone else had the same type of problem with water leaking into the antenna, apart from a leaking rear screen washer?
    Is a new antenna easily fitted, once the head cloth is down?
    This is after the dealership had already fixed a leaking rear washer six months ago, without letting on about the damage done to the antenna.
    If anyone can help with this, please do so.
    cheers loopie6
  2. Re: 2005 allroad gps antenna
    May 2007
    knee deep in clunge
    14 Post(s)
    Very common and its nothing to do with the dealers repair.Also consider the coax cable may also be at fault but 90% of the time its the roof gps and you can remove the rear trim and lower theroof lining and remove interior light unit it access the 22/24mm securing nut
  1. Please Help Shark Fin Antenna?
    By wh431 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 03-07-2008, 02:17 PM
  2. Sharks Fin Antenna
    By richard@thebrae in forum Passat - B5 Forum - 1997 -2005
    Last Post: 07-06-2008, 11:15 PM
  3. Question Radio Antenna
    By mkc in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 28-05-2008, 06:08 PM
  4. GPS Antenna
    By FLENG2008 in forum Golf MK4 - 1999 - 2004
    Last Post: 11-05-2008, 12:35 PM
  5. Audi Allroad (...to 2005) - Air Compressor
    By Cooperman in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 19-03-2008, 08:31 PM
