Thread: Econ button - when to use?
Results 1 to 10 of 11
  1. Econ button - when to use?
    Aug 2008
    My golf (04 GT TDI) has the dual ( think - each side has a dial and digital screen anyway) climate control.
    I seem to keep it around 21 on 'Auto'.
    How much extra MPG does this use approx (i know very hard to say but approx).
    Should i have this on ALL the time?
    I believe i should not use the 'off' button very often?
    When should i be using the ECON button and what exactly does it do?
    On a side note under the 'off' button in the centre switch is blank - what is the optional button?
    Thanks,
  2. Re: Econ button - when to use?
    Dec 2006
    In short... ECON turns the air con off.
    In regards to MPG... not much really..
    I tend to leave it on all the time..
    Rick
  3. Re: Econ button - when to use?
    Aug 2008
    Quote Originally Posted by RickT View Post
    Rick
    What does it leave on then? The climate aspect? What exactly - i don't get it?
  4. Re: Econ button - when to use?
    May 2008
    Leeds, W Yorks
    Off turns the air off- no air. Econ turns the air con off- no chiller, therefore warm if weather is warm and no dehumidifying effect, so steamy windows if wet! I find econ saves about 5%, you can try it on a journey. Cruise with it on, then econ and watch your average mpg drop. Its recommended to not use econ all the time. The air con compressor should be run at least once a week as there is lubricant in the refrigerant which keeps everything working well.
  5. Re: Econ button - when to use?
    Coventry
    so when you turn it off with the centre off button, the little yellow led light lights up to say it is off.
    econ - is it off when its led light is on or off.
  6. Re: Econ button - when to use?
    May 2008
    Leeds, W Yorks
    Oddly, econ is on when the light is on. ie the air con is off when the light is on. You can tell by turning the temp down, say, 15 deg C. you will feel the cooling when econ os off. (aircon on)
  7. Re: Econ button - when to use?
    Aug 2008
    Quote Originally Posted by tomjj View Post
    Thanks,
    Thanks - it makes sense.
    Anyone know the answer to my last bit by any chance? It's bugging me
  8. Re: Econ button - when to use?
    Sep 2008
    Do you mean the little round 'button' surrounded by the heated rear window, recirculation and econ buttons?
    This is the interior temperature sensor for the Climatic air-conditioning.
  9. Re: Econ button - when to use?
    Sep 2008
    Though, I guess you're referring to the 2-Zone climate control.
    In both cases, it is the interior temperature sensor.
    It also combines a light sensor to measure the amount of light in the car in order to reduce the temperature if it's very sunny. This is definitely the case for the 2-Zone climate control but I'm not sure if this is true of the Climatic system.
    For those more technically minded it is a 'NTC thermistor and photodiode'.
  10. Re: Econ button - when to use?
    Aug 2008
    I tried to explain this to my girlfriend the other day. Econ button etc. Gave up after 10 mins..................women heh!!
    NOW - A3 SPORTBACK 2.0 TDI
    With lots of lazy bits
    PREVIOUS - 03 LCR 270 bhp (OMG!)
    - 02 leon cupra 1.8T (I love VAG cars!)
  1. ECON Button???
    By curryholic in forum Touran - Sharan - Caravelle
    Last Post: 28-01-2010, 07:55 PM
  2. ECON button
    By noshock65 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 12-08-2008, 02:20 PM
  3. Please Help A4 Cab 'Econ' button stays on whilst using Climate Control
    By mrug35 in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 04-07-2008, 12:12 AM
  4. Replies: 0
    Last Post: 02-11-2007, 05:36 PM
  5. A4 Econ Heater Button Stuck On
    By Colin Preece in forum Archive posts
    Last Post: 09-03-2007, 08:53 PM
