Thread: A6 Avant 2.4 V6 starting trouble
Results 1 to 9 of 9
  1. A6 Avant 2.4 V6 starting trouble
    blocko Guest
    My 1999 A6 Avant 2.4 V6 is slow at starting. It takes about 3 seconds to turn it over, but sounds like it is struggling. You can smell the unburnt fuel too.
    Any ideas at all please??
  2. Re: A6 Avant 2.4 V6 starting trouble
    Southern County Softy
    20 Post(s)
    knackered battery !
    A4 2.5 tdi QS (mapped)
  3. Re: A6 Avant 2.4 V6 starting trouble
    blocko Guest
    Quote Originally Posted by kite View Post
    knackered battery !
    You think? I was thinking this, but it had a new one around 2 yrs ago. It drives just fine. The battery dial (voltmeter is it?) shows it at around 14v.
  4. Re: A6 Avant 2.4 V6 starting trouble
    20 Post(s)
    Volt meter shows the charging rate, so your alternator is good.
    I would get the battery checked for dead cells.
  5. Re: A6 Avant 2.4 V6 starting trouble
    blocko Guest
    Thanks very much!
  6. Re: A6 Avant 2.4 V6 starting trouble
    May 2007
    could be a faulty temp sensor. Had to change mine as it was reading 12 degrees to low, so kept flooding the engine.
    Does your engine reach 90 degrees after 4-5 miles? if not the sensor could be the issue.
  7. Re: A6 Avant 2.4 V6 starting trouble
    blocko Guest
    Quote Originally Posted by lonky View Post
    I will check and see.... thankyou
  8. Re: A6 Avant 2.4 V6 starting trouble
    May 2007
    Just to confirm on the battery angle.
    Voltage with ignition on, and engine off, (not having been run for several hours)
    should be about 13 volts.
    when cranking it should not drop below 10.5 volts. (you need a meter on the battery)
    if it drops to 8v then you have a weak cell in the battery.
    modern batterys last 2 - 5 years dependant on quality, and use.
  9. Re: A6 Avant 2.4 V6 starting trouble
    blocko Guest
    Thanks.... It is not the temp sensor, so it must be the battery. Will check it today
  1. Starting trouble???
    By jonnocooper1987 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 07-06-2008, 08:01 PM
  2. MK3 1.8 Having trouble starting..
    By Mattster in forum Golf MK3 - 1993 - 1999
    Last Post: 21-05-2008, 11:52 PM
  3. trouble starting
    By DJK in forum 80 - 90
    Last Post: 29-02-2008, 02:17 AM
  4. V6 trouble starting
    By Vandy in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 16-07-2007, 10:21 AM
  5. Trouble starting A3
    By dools in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 03-01-2007, 02:11 AM
