Thread: S6 Gear Shift locked
  1. S6 Gear Shift locked
    May 2008
    I have a 2002 S6 and everything was working fine, parked in my driveway, and when I started the car, I couldn't engage it into a gear. I noticed that the little brake light beside the park gear was not on and the shifter was "locked". But if I turned off the car and just moved the key to the first stage..before the dash light up that I can shift
    Has anyone had this problem or know what it is?
  2. Re: S6 Gear Shift locked
    I'm not into Auto's but if you had to have your foot on the foot brake to get out of park before the fault then I would suspect the brake pedal switch has failed. Regards Pete
  3. Re: S6 Gear Shift locked
    May 2008
    Thanks Peter D for your impute. My research has also been leaning to the brake switch failure. Too bad here is the US most service guys that know to work on Audi are closed.
  4. Re: S6 Gear Shift locked
    PM me and with your email adress and I'll send you the drawing. There are two switches up in the pedal box, one for the brake lights and interlock and one for the cruise control. Check if you brake lighs are working.. Regards Peter
  5. Re: S6 Gear Shift locked
    May 2008
    Hi Peter, I checked my brake lights and they are working. My email is zgruich@neo.rr.com.
    Can you tell me where the brake locking sensor is located? Any diagrams would be helpful. I will have a tech guy check the fuses later today, but I need to locate the fuse box first. This engine bay is packed and I do not see.
    Thanks,
  6. Re: S6 Gear Shift locked
    May 2007
    some of the brake petal switchs have two contacts, one for the lights , the other for the selector locking solinoids. If when you are pressing the brake pedal down you don't here a click, it is either switch, solinod or lack of power, i.e. loose wire or fuse.
  1. Question Stiff Gear Shift
    By damjee in forum Passat - B5 Forum - 1997 -2005
    Last Post: 21-05-2008, 07:43 PM
  2. Door capping and gear shift trim
    By FrecksGd in forum Audi A3 - Archive Topics
    Last Post: 24-09-2007, 09:17 AM
  3. VW BORA- Gear Shift problem
    By Lyndon in forum Bora - 1998 - 2005
    Last Post: 25-07-2007, 09:36 AM
  4. Short Shift for A4
    By richjthorpe in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 26-02-2007, 02:41 PM
  5. Bulb replacement in Automatic Gear Shift
    By 6huckle5 in forum Touran - Sharan - Caravelle
    Last Post: 23-01-2006, 10:23 PM
