Thread: Flashing colant light and no brake warning light
  1. Question Flashing colant light and no brake warning light
    Hello all, im back again, this time with some strange happenings. My 2.6 cab (94 plate) is running fine however does anyone know why my coolant warning light flashes but the temp and coolant is fine inc all levels,ive taken out the bulb behind the dash for now as it is driving me mad.
    And secondly i have replaced the brake warning bulb behind the dash because the last one was broken and hanging on wires when i brought the car but it doesnt light up when the ignition is turned on??
    many thanks for all your help so far.
    Cookie
  2. Re: Flashing colant light and no brake warning light
    Southern County Softy
    20 Post(s)
    Try cleaning the probes in the coolant tank, give them a scrape with a screwdriver.
    A4 2.5 tdi QS (mapped)
  3. Re: Flashing colant light and no brake warning light
    Cheers mate i'll give them a scrape and see if it has any results
  4. Re: Flashing colant light and no brake warning light
    Gwent
    The coolant temperature sensor also gives an overtemperature alarm. It is possible for the alarm circuit to fail and the gauge circuit to remain intact, to test, try putting the lamp back in and unplugging the sensor?
    The sensor was used on many different models, more info here:
    http://www.sjmautotechnik.com/troubl...ing.html#gauge
    2001 Passat Sport tdi 130hp
    1990 Audi coupe 20v x 2
  5. Wink Re: Flashing colant light and no brake warning light
    Scottie many thanks for your top tip i will try and have a look this weekend
    regards
    Cookie
  1. ABS and brake warning light flashing
    By Leon Fletcher in forum VCDS - General Questions
    Last Post: 31-07-2008, 01:27 PM
  2. A6 Yellow ABS Light And Flashing Red Brake Light
    By mikekirchner in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 24-01-2008, 08:15 PM
  3. ABS light on with flashing red brake light
    By P471 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 28-11-2007, 09:26 PM
  4. ABS light on with flashing red brake light
    By P471 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 25-10-2007, 06:02 PM
  5. Brake fluid warning light with ABS light
    By radar1022 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 02-04-2007, 03:28 PM
