Thread: 1995 caravelle 2.4 diesel help required
  1. 1995 caravelle 2.4 diesel help required
    Sep 2008
    Am new to this forum so dunno if i posted in correct place for this question.
    i have a 1995 2.4 d manuall VW Caravelle.
    Question:
    my fuel gague and water temp gague do not work 'correctly' and sometimes not at all.
    To get it to work ( which then mostly gives an incorrect reading) you have to bang the top of the dash.
    am told its a little chip in behind the gagues (dioid or somethin) that doesnt make contact or has a loose connection.
    Can anyone confirm this or tell me a little about it and whats required to fix???
    (in the hope of avoiding a mechanic having to remove to check)
    thanks in advance
    Gav
  2. Re: 1995 caravelle 2.4 diesel help required
    Sep 2009
    Cardiff
    Hi Gav,
    That is common problem on all cars not just yours.
    Basically its an issue with the earth and the connections. Take them out and give them a clean - use a bit of sand paper on the contacts to remove any residue. Job done.
    Nick.
  1. Please Help caravelle T4 2.4 diesel
    By m.colebrook in forum Chat - Anything with wheels
    Last Post: 06-05-2008, 09:14 PM
  2. Caravelle 2.4 Auto Diesel 1995
    By NOK in forum The Commercial Range
    Last Post: 01-03-2008, 10:46 AM
  3. Caravelle 2.4 Auto Diesel 1995 AAB Engine
    Last Post: 30-12-2007, 07:02 PM
  4. vw westfalia california highway 2.4 diesel 1995
    By the staggerer in forum The Commercial Range
    Last Post: 25-09-2007, 11:36 PM
  5. 2.4 diesel T4 Caravelle Panel Van, what to look for?
    By Mattygreg05 in forum The Commercial Range
    Last Post: 31-08-2007, 05:23 PM
