Thread: P0234 Engine overboost Condition
Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
  1. Re: P0234 Engine overboost Condition
    Liverpool
    Quote Originally Posted by potnoodle View Post
    Update: Got the car up on ramps today and did a visual inspection of hoses , all seemed fine, worked the vanes by hand and didn't notice any sticking or noises, so took off the pipe with the MAP sensor fitted to it and what looks like oil started dripping out, cleaned the pipe, run a coule of kettles of boiling water over the map sensor refitted it and put the lot back together, took it for a very hard driving session on the motorway, and now can not get it to fail into limp mode now. Happy with the result, not so happy with oil being in the pipe between the cooler and inlet manifold and covering the MAP sensor. checked oil when I got home and it is about a litre overfull, going to drain a bit tomorrow, but now need to find out if this is the reason for the pipes having oil in or is this normal?
    Checked service history and oil was changed at VW dealers 700 miles ago.
    Hi Potnoodle, how is your car faring now? Did you use the spray cleaner as advised to clean the vanes? I've been having similar problems for a while now, my car has done 157k miles; all I do is switch off and on the ignition to reset, but would really like to resolve this issue without having to get a garrage do guess work on my car. I would really be grateful if you can update me and if there is any one here who can help carry out this task (I'm not skilled enough!). I work around the m3 down south through the week and back in Merseyside Friday to Sunday. Obviously would pay reasonable amount for work done.
  2. Re: P0234 Engine overboost Condition
    Liverpool
  1. Question Belt for Air Condition Unit?
    By karachi_kops in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 11-08-2008, 08:34 PM
  2. air condition
    By suomis in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 07-07-2008, 08:44 AM
  3. battery condition
    By waggy in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 30-05-2008, 08:42 PM
  4. P0234-turbo Overboast
    By jp4500 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 17-04-2008, 06:18 PM
  5. Over Boost Code p0234
    By whiteturbo in forum Archive posts
    Last Post: 24-01-2008, 04:13 AM
