Thread: Golf Driver running problems + VAG codes
  1. Golf Driver running problems + VAG codes
    Jun 2007
    My newly aquired 1995 Mk3 Golf 1.8 Driver is causing me some grief.
    It stopped completely the other day in torrential rain but has been fine since. It has now developed an erratic idle after revving, it drops to about 800rpm then evens out about 1100rpm and sometimes when driving loses power but seems fine over 3k.
    I was initially thinking maybe a fuel pump (157thousand miles) but today I run a diagnostic on it and got the results shown below.
    After clearing them 00282 & 00516 return immediately, I assume 0516 because the engine is not running?
    But if anyone can tell me in English what 00282 means or what action to take, or where to find/replace the TPA with the implausible signal is?
    Thx
    TonY
    Chassis Type: 1H - VW G/J/V Mk3
    Scan: 01,02,03,08,15,25,56
    Address 01: Engine
    Controller: 3A0 907 311
    Component: 1,8l R4 MONO 1.2.3 DGC
    Coding: PMC 01
    4 Faults Found:
    00282 - Throttle Position Actuator (V60)
    27-00 - Implausible Signal
    00515 - Shareware Version. To Decode all DTCs
    03-00 - Please Register/Activate
    00670 - Shareware Version. To Decode all DTCs
    00516 - Closed Throttle (Idle) Position Switch (F60)
    30-10 - Open or Short to B+ - Intermittent
    Readiness: N/A
    Skipping Address 15-Airbags
    Address 25: Immobilizer
    Controller: 1H0 953 257 B
    Component: IMMO VWZ3Z0S0182569 V00
    Coding: 09600
    Shop #: WSC 00000
    No fault code found.
  2. Re: Golf Driver running problems + VAG codes
    Southern County Softy
    20 Post(s)
    00282 - Throttle Position Actuator (V60): Implausible Signal
    Possible Symptoms
    Idle Speed too high
    Idle Speed Regulation in Limp Mode
    Cruise Control System (CCS) not working
    Possible Causes
    Throttle Position Actuator (V60) jammed
    Wiring/Connectors from/to Throttle Position Actuator (V60) faulty
    Possible Solutions
    Check Throttle Position Actuator (V60)
    Check Cruise Control System (CCS)
    00282 - Throttle Position Actuator (V60): Short to Ground
    Possible Causes
    Throttle Position Actuator (V60) faulty/jammed (Stuck Closed)
    Possible Solutions
    Check Wiring/Connectors from/to Throttle Position Actuator (V60)
    00282 - Throttle Position Actuator (V60): Short to Plus
    Possible Causes
    Throttle Position Actuator (V60) faulty/jammed (Stuck Open)
    Possible Solutions
    A4 2.5 tdi QS (mapped)
  3. Re: Golf Driver running problems + VAG codes
    Canada
    Disconnect both battery cables and short them together for a few minutes. Make sure you have the radio code before attempting this.
    Remove and clean the ground connections at the ECM and below the battery tray.
    Clean the throttle body with a cleaner that's designed for your system.
    Reconnect the battery (this is called S.O.S. or Stuck On Stupid) or if taking offense, "a babbling idiot node"
    With you VAG tool... Got to
    01 Engine electronics
    04 Basic setting
    Type 060 and hit GO, the last field should display ADP .OK
    If not, replace the throttle body control module
    If you have an Automatic transmission and that last test passed
    04 Basic setting
    Type 063 and hit GO. Put the throttle down to the floor and hold it till the last field displays ADP .OK
    If a new OEM throttle body controller fails, replace the ECM.
    "God didn't play dice with the universe" Einstein
    "there are no answers, it's the choices that are made" AF
    Don't PM me for help, I don't answer them! If you're unable to post the details like year, make, model with a scan, I can't help you.
  4. Re: Golf Driver running problems + VAG codes
    Jun 2007
    Hi ecmbuster
    Its been behaving itself since I cleaned all the electrical connections. But thanks for a very concise & detailed "How To"
    Will store this info for the future
  1. Golf MK4 1.6 S Estate W REG Running problems
    By fat tonii in forum Golf MK4 - 1999 - 2004
    Last Post: 06-08-2008, 10:20 PM
  2. Bora V5 - Running like sh*t since I cleared fault codes.
    By RobBentley in forum Bora - 1998 - 2005
    Last Post: 06-02-2008, 03:29 PM
  3. mk4 Golf Running Problems
    By schonv967 in forum Golf MK4 - 1999 - 2004
    Last Post: 30-01-2008, 12:34 AM
  4. Golf Gt Tdi 150 Running problems
    By DWCARS in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 07-08-2007, 10:52 PM
  5. MARK 2 GOLF SLOW IDLE RUNNING PROBLEMS
    By LIZSTOBB in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 22-09-2006, 10:21 PM
